04-30-2013, 16:25 | #1 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1216263 Status: Offline Thanks Meter: 130 | Please help with Nokia N82! Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C080506A Using device: HTI, FW ver: 00.50, SN: 00008D8E Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: F79A267901CDEB544266A9D9EE80777734BB85C2 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021105 [RAPIDOYAWE ver: 1.1x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0800011765750052E0EC4BF9B05665E5375405E4 ASIC MODE ID: 00 ROOT KEY HASH: F2D76DFAFD66C7F195F278417DF05888 ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported Ids: 24200703, 24200704, 24200705, 24200706 Storage0: 00EC 0040 - 0121 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,NAND, asic:APE Suggested algorithm: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248 Supported Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS HASH: F8311F20A18CAD3B70A4F896C74DD8711E189EED Processing MCU file: RM-314_31.1.016_PR.C0R [BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 68.26 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 4003192101031105, 400C192101031105 Supported Ids: 24200705 Storing certificate [NPC, HWC, CCC, R&D]; @...OK Partitioning ...OK Erase size: 121.77 MB CMT FLASH,NOR area [00080000-0063401D] CMT FLASH,NOR area [00000000-0005FFFF] CMT FLASH,NOR area [00880000-00EFFFFF] erased in 26.087 s Prog.status for Asic CMT ... NOR: OK NAND: OK Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: F8311F20 [RAP Certificate 91 v1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent APE X-LOADER block sent APE KEYS block sent APE PRIMAPP block sent APE X-LOADER block sent APE KEYS block sent APE PRIMAPP block sent APE SOS+XZIP block sent APE PASUBTOC block sent APE PAPUBKEYS: F8311F20 [APE Certificate 91 v1] sent APE SOS+UPDAPP block sent APE SOS+CORE block sent APE SOS+ROFS block sent Prog.status for Asic APE ... NOR: OK NAND: OK Programming completed in 3 min 15.879 s Processing PPM file: RM-314_31.1.016_PR.v72 [BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 14.52 MB Supported Ids: 400C192101021105, 4003192101021105, 4003192101011105, 400C192101011105, 4003192101031105, 400C192101031105 Supported Ids: 24200705 Partitioning ...OK Erase size: 25.12 MB erased in 0.062 s Prog.status for Asic APE ... NOR: OK NAND: OK Flash programming ... APE SOS+ROFX block sent Prog.status for Asic APE ... NOR: OK NAND: OK Programming completed in 40.817 s Processing CNT file: RM314_31.1.016_017_uda_3.fpsx [BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 30.12 MB Supported Ids: 4003192101021103, 400C192101021103, 4003192101002003, 400C192101002003, 400C192101011103, 400C192101021105, 4003192101021105, 400C192101031103, 4003192101031103 Supported Ids: 24200705 Erase size: 136.06 MB APE SOS-USERerased in 0.005 s Prog.status for Asic CMT ... NOR: OK NAND: OK Flash programming ... Prog.status for Asic APE ... NOR: OK NAND: OK Programming completed in 1 min 50.773 s Total time for flashing process(boot+erase+write) was 6 min 21.794 s Thanks in advance. |
04-30-2013, 18:34 | #4 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Yes, your file is up to date. Use this file, install, placed as MCU, or use market dropdown to load. Nokia_firmware_RM-313_ENO_SW_2008wk06_v3.0.exe - Flash ENO - DO firmware update as usual. |
