03-06-2010, 18:01 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Algeria
Member: 220195 Status: Offline Thanks Meter: 49 | Please solve with "KASPERSKY" Please fix this Last edited by bachirDraria; 03-06-2010 at 18:10. |
The Following User Says Thank You to bachirDraria For This Useful Post: |
03-06-2010, 18:10 | #2 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | am using also kaspersky no problem yet try to re install program |
The Following User Says Thank You to WAJID PNR For This Useful Post: |
03-06-2010, 18:23 | #3 (permalink) |
Member: 220195 Status: Offline Thanks Meter: 49 | I have original "Kasperky Anti-virus 6.0 for Windows Workstations" with xp, application can't open |
The Following 2 Users Say Thank You to bachirDraria For This Useful Post: |
03-07-2010, 08:16 | #5 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Venezuela
Member: 594580 Status: Offline Thanks Meter: 157 | Bro i also have kaspersky and you are right, i was facing your same problem but i could find solution, you just need add mobileex.exe to trusted zone and that is it.. Good luck.. |
The Following User Says Thank You to richiricherd For This Useful Post: |
03-07-2010, 10:52 | #8 (permalink) |
Member: 220195 Status: Offline Thanks Meter: 49 | I tried all solutions before posting but without result The only solution is to uninstall KASPERSKY But this is not a solution We must find a solution because it is impossible to remain unprotected |
03-07-2010, 11:06 | #10 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Indonesia
Member: 1169189 Status: Offline Sonork: 100.1591528 Thanks Meter: 94 | just my opinion. maybe when you try to install, the kaspersky already block/clean the related file/s. many antivirus give logs for any operations. so check it. have you try to delete new antivirus database? until now my antivirus do not detect execryptor or any PE heuristic only themida, i must add it to my antivirus as clean program. |
The Following User Says Thank You to sijibae For This Useful Post: |
03-07-2010, 11:23 | #11 (permalink) | |
Member: 220195 Status: Offline Thanks Meter: 49 | Quote:
Personally I am addressing to the MXKEY'developer to find a solution as SagMaster and other not to the kind of you'r response | |
03-07-2010, 11:36 | #12 (permalink) |
Member: 1169189 Status: Offline Sonork: 100.1591528 Thanks Meter: 94 | But it's impossible if the solution is downgrading the security itself. Antivirus will detect strange pe. if pe protected with strongest protector it will produce some strange code inside pe. and execryptor to be no.1 to produce garbage codes inside pe hope mx-key team read this thread and give some solution for your problem. thanks |
03-07-2010, 12:22 | #14 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 43
Member: 39948 Status: Offline Thanks Meter: 68 | if you wanna use mxkey with KAV installed. just disable your KAV. restart pc. now your mxkey can open. |
The Following User Says Thank You to mentari For This Useful Post: |
@Infinity Team- Please solve module not opening problem with Yahoo Messenger | PASSIONATE_BOYS | Infinity-Box | 63 | 12-12-2009 11:30 |
Please help with registration of new box??? [SOLVING] | geovanny78 | FuriousGold | 7 | 09-01-2009 18:08 |
W200 Phone Locked- Please Contact Service Center Not Solved With Infinity | jalesar | Infinity-Box | 3 | 04-02-2009 06:42 |
FURIOUS PROBLEM with SUPPORT...........Please solve | v11 | FuriousGold | 3 | 09-12-2008 15:57 |
