Old 02-15-2013, 14:01   #1 (permalink)
Member: 1154494
Thanks Meter: 3
Exclamation Need Help Asha 200
Nokia Asha 200 hanging and restarts...
Here is the bus check
MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN:
Using device: USB Phonet  and HTI, FW ver: 00.50, SN:
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: nmwcdnsuc, ver: 7.1.32.75
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
 Boot mode: 0xCC
 EBL version major/minor: 10.37
 EBL version: Quantum_Bootloader_10.37_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
 Flash settings: 0/1024, size: 0x04000000
 1 Block regions:
  512 x 0x00020000 = 0x04000000
EBL ready !
Waiting for USB device removal ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 2CA36857
Verifying communication to device OK.
Phone type: RM-761 (Nokia 200)
SW version: V 11.81 20-08-12 RM-761 (c) Nokia
Imei plain:
Product code: 059K928
Detected as DCT4 phone, check Generation selection !
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: 06150123008027, ver:
MMC password:
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net:
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
And here is the Self Test log
Phone Type: RM-761
ID        Test name                       Startup   Result
33   SIM_LOCK                      N          passed
93   SECURITY                      N          passed
90   PWR_KEY                       N          passed
2    CURRENT_CONS               N          passed
43   LCD                              N          passed
44   LPRF_AUDIO_LINES          N          passed
21   LPRF_IF                         N          passed
7    KEYBOARD_STUCK            N          passed
22   CAMERA_IF                     N          passed
71   BT_WAKEUP                    N          passed
96   HOOKINT                        N          passed
101  BTEMP                          N          passed
118  RF_ANTENNA                  N          passed
112  CDSP_PA_TX_POWER       N          passed
227  SLEEP_CLOCK_FREQ         N          passed
52   KEYB_LINE                      N          passed
10   ADC_IF                          N          passed
50   MEMORY_CARD_IF            N          !no signal
53   SIM_MULTIPLEXER_IF        N          passed
17   RF_PLL                            N          passed
45   FEM_CURRENT                   N          !no signal
47   SECURITY_FUSE                 N          passed
114  IO_EXPANDER_IF                N          passed
Checked and failed here
=> HTI On USB, what this box can do?
Super SD Auth and Repair SD not working, anybody can give some idea what is going on?
Old 02-16-2013, 07:29   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
It's XGold Phone,
Flash it with Latest Version Firmware will solve it.
BR.
ZUBER
Page generated in 0.12175 seconds with 8 queries
