this is possible ????????????????? i have a nokia 3110c when set is come my tabel show contect service i connect set with mx key and write 1or 309 sector pm but not provlem solv i do this 1-write new hwc and ccc but same 2-full erase 3-full flash 4-write backup 5-write pm but same i do maney set solv contect service problem but this is very difecult so i reqest all expert plz sare my problem;);) |
first post bus check log...........it's basic........or selftest log |
put a tick on load from server icon pm uth,wait till supper dongle authorized, try many times if u success to get server ,press write note,cable is very important, use good cable if still face problem ,controll panal,put windows firmware off restart ur pc and repeat again,will be ok |
post log _____________ |
here is log Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.21 05-11-08 RM-237 (c) Nokia. Imei plain: 35318303657150-0 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353183036571500 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
and all detail here Quote:
tick Load RFBB from server and press RFBB to Server then press write............problem solved still problem contact yahoo messanger |
i found this problem after hard work but i dont know how to solv this provlem achully my phone ver 7.30 Product Code: 0544321 and this is Original Product Code: 0581437 i downgrad this file but but not change product code i need 7.30 ver flash file this product code 0581437 i serch in support site but no found plz help here is log Quote:
if your problem not solve yet go to the link____ http://forum.gsmhosting.com/vbb/f550...ution-1031277/ |
not solv provlem |
i think downgrade is possible, and same product(Original Product Code: 0581437) 0581437 this product code not avilable 7.30 |
FIRST SD REPAIR, THEN Load RFBB from server and press RFBB to Server then press write............problem solved |
