03-01-2013, 15:57 | #1 (permalink) |
Major Poster Join Date: May 2007
Member: 512505 Status: Offline Thanks Meter: 2 | Is it Possible to repair Nokia 5233 Simlock |
03-01-2013, 16:41 | #3 (permalink) |
Member: 512505 Status: Offline Thanks Meter: 2 | MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: xxxxxxxx Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000xxxx Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1AC00112EBAC005252AE4F80B43201DCEAE133DE CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. Reading CMT NPC (0xFF bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0xFF bytes). Reading CMT HWC (0xFF bytes). Reading CMT R&D (0xFF bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia 5800 XpressMusic USB Phonet, PORT_ID: ECA1E48 Verifying communication to device OK. Phone type: RM-625 (Nokia 5233) SW version: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia ApeCoreSw: V 51.1.002 Imei plain: 35626404xxxxxx-3 Battery voltage: 3994 mV, current: 326 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Market items is empty, please select the correct products path ! |
03-02-2013, 07:11 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
You cannot Repair corrupted Simlock of SL3 Phone with Credits, Have to Restore Backup if present or buy Factory RPL. BR, ZUBER | |
