11-09-2009, 19:19 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Age: 45
Member: 348590 Status: Offline Sonork: 100.108198 Thanks Meter: 200 | Problem Change Imei *For example in 1208 the operation is successful, but the team has no signal. *In 2630 and 2760 models always fails *Etc etc etc PhoneType:RM-299 SwVersion: V 05.61 18-04-08 RM-299 (c) Nokia MCU file: rm298__05.61.mcusw Trying to find patch position ...OK New Imei: 011998005220617 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Error flash config request! Retrying ... OK, case id: 4 New Imei: 011998005220617 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 881C [ST M58LR256JU,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0007AD6B:3B8ADA60 Area [01000000-0101FFFF] erased in 0.578 s Area [01080000-0109FFFF] erased in 0.579 s Programming ... Programming completed. Phone not responding ! Phone not responding ! ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 881C [ST M58LR256JU,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0007AD6B:3B8ADA60 Area [01000000-0101FFFF] erased in 0.562 s Area [01080000-0109FFFF] erased in 0.563 s Programming ... Programming completed. Last edited by :::MACUGSM:::; 11-09-2009 at 19:27. |
Problem changing IMEI Nec 342i | gsm flying free | Infinity-Box | 8 | 02-10-2008 15:13 |
ver 7.20 problem changing imei p510 | redboxtechnolog | UST Pro II | 2 | 11-26-2004 00:48 |
Problem changing IMEI | roger1 | VLSI, Conexant, Skyworks and Old Models | 0 | 01-20-2003 22:43 |
Problem Changing imei on Z5 | Flash83 | Sony | 0 | 02-03-2002 14:38 |
