07-01-2011, 19:48 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: where smokers Age: 42
Member: 761005 Status: Offline Thanks Meter: 430 | problem flash nokia 1661 (ANSWERED) logs MXKEY Serial: [FT SCR2000 0] - C07499AC Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.8.14.0, NTMP ver: 1.6.6.1 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 002F730DA3BDA66 ASIC type: 11 UEM Imei: 35523303345845 Flash Imei: 35523303345845 RPL saved to "D:\3.4\data\backup\RPL\35523303345845_BACK.rp l" Processing MCU file: rh122_003.100 [DCT4,DCT4 ALGORITHM] size: 2.37 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 002F730D:2984DA60 Area [01000000-0100FFFF] erased in 0.610 s Area [01010000-0179FFFF] erased in 47.719 s Area [017A0000-017EFFFF] erased in 2.281 s Area [01F00000-01FDFFFF] erased in 0.172 s Flash programming ... Programming completed in 21.516 s File Processed in 1 min 21.375 s Processing CNT file: rh1220_nai03.10ia [DCT4,DCT4 ALGORITHM] size: 184.46 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 002F730D:2984DA60 Area [01760000-0179FFFF] erased in 2.094 s Flash programming ... Programming completed in 1.718 s Content extract fail, continue anyway ... File Processed in 35.578 s Processing PPM file: rh122_003.10ia [DCT4,DCT4 ALGORITHM] size: 2.73 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 002F730D:2984DA60 Area [01240000-0125FFFF] erased in 1.063 s Area [01260000-0175FFFF] erased in 31.594 s Flash programming ... Programming completed in 24.718 s File Processed in 1 min 8.359 s Total time for flashing process(boot+erase+write) was 3 min 5.312 s any idea brothers |
07-02-2011, 11:12 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, try to fully erase first,and repeat flashing. - advacne > get addr, don't mark 'safe erase', press erase. - reflash. if still the same, check phone hardware. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
