11-14-2009, 12:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: rainak bazar jalandhar
Member: 1002949 Status: Offline Sonork: 100.1582346 Thanks Meter: 273 | problems in mxkey 1. today i flashed a n72 (restarting problem) but it got dead in mxkey,luckily i flashed again in jaf with no problems and it revived again 2. i tryed to unlock 5000d(rm-362) v4.60 but it gave error but in jaf it was unlocked in seconds mxkey team please fix the bugs as soon as possible |
11-14-2009, 12:10 | #2 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: PANGANDARAN BEACH Age: 44
Member: 427685 Status: Offline Thanks Meter: 103 | Quote:
11-14-2009, 13:28 | #4 (permalink) | |
Member: 1002949 Status: Offline Sonork: 100.1582346 Thanks Meter: 273 | Quote:
sorry i forgot to save the logs | |
11-15-2009, 14:10 | #5 (permalink) |
Member: 1002949 Status: Offline Sonork: 100.1582346 Thanks Meter: 273 | here is another one 1200 (working) but failed to flash Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.10913, Date: 05-11-2009 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00827B81A3BDA66 ASIC type: 11 UEM Imei: 35************* Processing file: rh99_05.800 as MCU [DCT4,DCT4 ALGORITHM] size: 2.26 MB Supported Ids: 2292 Boot error: 03 00 00 72 UPP not responding ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Flashing terminated with error(s) in 3 min 36.000 s RX Buffer: 33759602415907F642B372 |
11-15-2009, 14:18 | #6 (permalink) |
Freak Poster Join Date: Oct 2008 Location: philippines Age: 55
Member: 883572 Status: Offline Thanks Meter: 63 | i tried flasshing dct3 3310 n gave me rx buffer error too. i revived it with ufs3. whats up with all the rx buffer error pls mxkey support fix these |
New update problem in mxkey | <<<MEGATRON>>> | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 03-25-2010 15:36 |
jaf box problem in mxkey | Abidqadeer | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-09-2010 15:02 |
New in mxkey here, need help for this problem.... | genehack | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 08-07-2009 12:42 |
found problem in mxkey .. must reply please | MYUNLOCKING | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 08-06-2009 03:54 |
