02-15-2011, 11:02 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Product Code missmatch ! pc is same, but still gives this error..so SECURITY_TEST failed!..and contact service.. Reading CMT NPC (0x168 bytes) Original Product Code: 0515620 Reading CMT VARIANT (0xB8 bytes) Product Code: Product Code missmatch ! Reading CMT CCC (0x0 bytes) Reading CMT HWC (0x0 bytes) and phone info, Product Code: 0515620 ApeCoreSw: V 4.0735.3.0.2 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! full erased..flashed with same product code (0515620) and modified pm with sx4 auth..then recovery certificate... but still same.. what is next..? |
02-15-2011, 12:49 | #2 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
1st repair SECURITY_TEST failed! , Recover Certificate in IMEI & SECURITY If not repair then go to PM & do PPM AUTHO / Super SD AUTHO > after success Authories Tick on Load RFBB from server & Click on Write Post result | |
02-15-2011, 13:00 | #3 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
02-15-2011, 13:03 | #4 (permalink) | |
Code: Using cached productData[09200205C9AF5550D7FE47E78D5D8F060D2455F8] ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized :)! SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.5 Updating RFBB data ... Writing section 1... Writing section 309... Done. and,, SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! | |
02-15-2011, 14:39 | #5 (permalink) | |
Then try Recover Certificate As shown | |
02-15-2011, 15:04 | #6 (permalink) |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | yes sir i did it too.. Code: Begin Certificate Request ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.5 Updating PRODUCTCODE (0515620)... OK [/COLOR]APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: 9FC34FF8E9B3DFDFBC90A80E97CFFC4E1B67EC3A ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 09200205C9AF5550D7FE47E78D5D8F060D2455F8 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 10.6.0 revision: 0.0 size: 0x3C40 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.28.0 revision: 0.0 size: 0x23220 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Updating CMT NPC ...OK Updating CMT VARIANT ...OK Certificate programmed successfully ! |
02-16-2011, 17:17 | #12 (permalink) | |
Code: Phone Type: RM-133 SW version: V 05wk47v51.4 29-08-07 RM-133 (c) Nokia. ID Test name Startup Result 88 TAHVOINT Y passed 46 UEM_CBUS_IF Y passed 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 33 SIM_LOCK N passed 93 SECURITY N !failed ! 90 PWR_KEY N passed 2 CURRENT_CONS N passed 20 BACKUP_BATT N passed 58 CMT_APE_WAKEUP N passed 56 SLEEPCLK_FREQ N passed 42 RADIO N passed 96 HOOKINT N passed 101 BTEMP N passed 49 VIBRA N !not ready 8 MBUS_RX_TX_LOOP Y passed 108 EXT_DEVICE N passed 6 IR_LOOP N passed 7 KEYBOARD_STUCK N passed 21 LPRF_IF N passed 22 CAMERA_IF N !not ready 5 CAMERA_ACCELERATOR N !not ready 37 SEC_CAMERA_IF N !not ready 38 CAMERA_AUTOFOCUS N !not ready 44 LPRF_AUDIO_LINES N !not ready 59 MAIN_LCD_IF N !no signal 71 BT_WAKEUP N !NOT EXECUTED(03) | |
02-17-2011, 12:27 | #14 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Quote:
02-17-2011, 13:25 | #15 (permalink) | |
Registered User Join Date: Mar 2008 Location: karachi
Member: 726546 Status: Offline Sonork: 100.1578784 Thanks Meter: 555 | Quote:
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-05-2010 09:04 |
Orange IL, Nokia 5110 GSM codes... | rosso11 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-05-1999 21:38 |
