05-06-2012, 07:20 | #1 (permalink) |
Freak Poster Join Date: Oct 2008 Location: Pakistan
Member: 878435 Status: Offline Thanks Meter: 51 | Read this error 1616 flash I flash higher & low version but same Check this error use mx key 1 bus Check MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0853BAC Using device: HTI, FW ver: 00.50, SN: 00002E15 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012) Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version: Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits] CFI information: Flash settings: 0/1, size: 0x00800000 2 Block regions: 127 x 0x00010000 = 0x007F0000 8 x 0x00002000 = 0x00010000 EBL ready ! AFTER FLASH LOW & HIGHER VERSION MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0853BAC Using device: HTI, FW ver: 00.50, SN: 00002E15 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012) Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version: Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits] CFI information: Flash settings: 0/1, size: 0x00800000 2 Block regions: 127 x 0x00010000 = 0x007F0000 8 x 0x00002000 = 0x00010000 EBL ready ! Processing file: rh125_003.610-V3.6 Downloading item CODE:hw_f11_rh125_r03.610.fls, num block: 3, size: 4.04 MB Erasing area 0x00800000-0x00A0FFFE ...OK Programming completed in 41.328 s Erasing area 0x00C60000-0x00E5A5FE ...OK Programming completed in 42.391 s Erasing area 0x00FFC000-0x00FFC03E ...OK Programming completed in 0.172 s Checksum mismatch: Phone calculated 0xA1F3, software calculated 0x9BE4 Processing file: rh125_003.61ia-V3.6 Downloading item CUST:hw_f11_rh125_003.61ia.fls, num block: 1, size: 1.98 MB Erasing area 0x00210000-0x0040A6FE ...OK Programming completed in 42.156 s Checksum mismatch: Phone calculated 0xAE28, software calculated 0x5586 Processing file: rh1250_nai03.61ia-V3.6 Downloading item CUST:hw_f11_rh1250_nai03.61ia.fls, num block: 1, size: 351.83 KB Erasing area 0x00EB0000-0x00F0723E ...OK Programming completed in 6.984 s Checksum verified (0xB4F2) Total time for flashing process(boot+erase+write) was 3 min 41.453 s NOT DONE UI SETTING |
05-06-2012, 07:27 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. what is your status before & after flash, it's appear local mode or not, you should post full description for help. br, |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
