02-10-2010, 15:55 | #1 (permalink) |
No Life Poster Join Date: Mar 2005 Location: gsmwebstore
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | Reset Npc Imei 123455 i have a backup only Sim rpl and sd rpl Reset Npc Imei 123455 i have a backup only Sim rpl and sd rpl Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 05300114B83900581473EDDFF28C10D6AF3697C6 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22FE - 0000 6921 [Samsung K8S5615ETA,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 Original Imei: Empty Original Product code: Empty Phone Type: RM-217 (Nokia 6300) SW Version: V 07.30 07-05-09 RM-217 (c) Nokia. Imei plain: 12345610654321-? Product Code: 0537630 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Last edited by aukonline; 02-10-2010 at 16:05. |
02-11-2010, 10:29 | #3 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Lebanon Age: 42
Member: 134335 Status: Offline Sonork: 100.1578107 Thanks Meter: 42 | Imei: 35644201187716 Restoring RF/BB DATA from backup ... Updating RF ...OK Updating BB ...OK Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK RAP Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0F90011910660058B32B40831E37927D3D7686F1 ASIC MODE ID: 00 ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 00EC 0030 - 0060 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: ONENAND,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 RAP PAPUBKEYS is blank/erased. NPC verified Ok. Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating PRODUCTCODE (0545896)... OK Updating PSN (CBH125791)... OK Updating HWID (0411)... OK Updating SIMLOCK...Trying to update SUPERDONGLE_KEY ...OK Updating WMDRM_PD...OK Certificate programmed successfully ! Phone Type: RM-179 (Nokia N81) SW Version: V 06wk41v62.4 04-12-08 RM-179 (c) Nokia Imei plain: 12345610654321-? Product Code: 0545896 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! Imei net: 12345610654321? Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-11-2010, 10:35 | #4 (permalink) | |
Freak Poster Join Date: Dec 2009 Location: ifixedcellution.blogspot.com
Member: 1190236 Status: Offline Sonork: 100.1589642 Thanks Meter: 233 | Quote:
THREAD STARTER: Be sure your back-up is not like this imie:12345xxxx. go to nokia service tool module service tab imie & security imie rebuild write RPL that's all. | |
02-11-2010, 15:49 | #5 (permalink) | |
Member: 134335 Status: Offline Sonork: 100.1578107 Thanks Meter: 42 | Quote:
Thank you for your help but I tried more then 10 times to write RPL but IMEI is same 12345xxxx | |
02-12-2010, 14:27 | #6 (permalink) |
Member: 125366 Status: Offline Sonork: 100.1602649 Thanks Meter: 108 | But dear my problum is defrent i have a only sim rpl and sd rpl backup NOT a full Backup pm and rpl How we can write this .. BR aukonline |
plese help i lose my back rpl and reset npc | .::PATEL TELECOM::. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 09-13-2009 02:48 |
ask rpl and write rpl mathod. | wasim_mobile200 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 06-23-2009 19:03 |
<< MXKEY come now with 1000 MXlogger FREE credits for DCT4 RPL and DCT+ RPL >> | MANOLE | Service Products News & Updates | 0 | 03-24-2009 20:15 |
NFF dongle only For dct4 and dct+ RPL | Miftahudin | Nokia Fault Finder Box | 6 | 03-02-2009 07:41 |
