Old 02-10-2010, 15:55   #1 (permalink)
Member: 125366
Sonork: 100.1602649
Thanks Meter: 108
Reset Npc Imei 123455 i have a backup only Sim rpl and sd rpl
How we can write and restore backup
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 05300114B83900581473EDDFF28C10D6AF3697C6
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 22FE - 0000 6921 [Samsung K8S5615ETA,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
Original Imei: Empty
Original Product code: Empty
Phone Type: RM-217 (Nokia 6300)
SW Version: V 07.30 07-05-09 RM-217 (c) Nokia.
Imei plain: 12345610654321-?
Product Code: 0537630
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei plain is invalid !!!
Imei net: 12345610654321?
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-10-2010, 16:30   #2 (permalink)
Member: 294245
Sonork: 100.1602405
Thanks Meter: 115
r u use restore imei option
Old 02-11-2010, 10:29   #3 (permalink)
pcgeorge23's Avatar
Member: 134335
Sonork: 100.1578107
Thanks Meter: 42
Unhappy
Imei: 35644201187716
Restoring RF/BB DATA from backup ...
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0F90011910660058B32B40831E37927D3D7686F1
ASIC MODE ID: 00
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
ROM ID: A8C1D6713E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0030 - 0060 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: ONENAND,RAP
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS is blank/erased.
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating PRODUCTCODE (0545896)... OK
Updating PSN (CBH125791)... OK
Updating HWID (0411)... OK
Updating SIMLOCK...Trying to update SUPERDONGLE_KEY ...OK
Updating WMDRM_PD...OK
Certificate programmed successfully !
Phone Type: RM-179 (Nokia N81)
SW Version: V 06wk41v62.4 04-12-08 RM-179 (c) Nokia
Product Code: 0545896
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST failed!
Counter: 0/3, 0/10
Old 02-11-2010, 10:35   #4 (permalink)
i-Fixed's Avatar
Member: 1190236
Sonork: 100.1589642
Thanks Meter: 233
Updating RF ...OK
Updating BB ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC verified Ok.
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Nextime please post with guide, ok?
THREAD STARTER: Be sure your back-up is not like this imie:12345xxxx.
go to nokia service tool module
service tab
imie & security
imie rebuild
write RPL
that's all.
Old 02-11-2010, 15:49   #5 (permalink)
pcgeorge23's Avatar
Member: 134335
Sonork: 100.1578107
Thanks Meter: 42
service tab
imie & security
imie rebuild
write RPL
that's all.
Thank you for your help but I tried more then 10 times to write RPL but IMEI is same 12345xxxx
Old 02-12-2010, 14:27   #6 (permalink)
Member: 125366
Sonork: 100.1602649
Thanks Meter: 108
But dear my problum is defrent i have a only sim rpl and sd rpl backup
NOT a full Backup pm and rpl
How we can write this ..
BR aukonline
Old 02-12-2010, 14:53   #7 (permalink)
Temporary banned !!
sajib_ngage's Avatar
Member: 243500
Sonork: 100.1590322
Thanks Meter: 584
so say bye bye to your mobile if you don't have npc bekup..........................
Old 02-12-2010, 15:25   #8 (permalink)
imran78669's Avatar
Member: 1016083
Thanks Meter: 103
dear write ur sd rpl with jaf box
Old 02-12-2010, 15:33   #9 (permalink)
Member: 418499
Thanks Meter: 13
copy log process write rpl npc in here..
plese help i lose my back rpl and reset npc .::PATEL TELECOM::. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 09-13-2009 02:48
ask rpl and write rpl mathod. wasim_mobile200 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 06-23-2009 19:03
<< MXKEY come now with 1000 MXlogger FREE credits for DCT4 RPL and DCT+ RPL >> MANOLE Service Products News & Updates 0 03-24-2009 20:15
NFF dongle only For dct4 and dct+ RPL Miftahudin Nokia Fault Finder Box 6 03-02-2009 07:41
Page generated in 0.20578 seconds with 10 queries
