SECURITY_TEST failed! After Repair sd scan Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35571802742392-8 Product Code: 0537289 ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 ApeVariant: V 4.0839.42.2.1-08 27-09-2008 RM-133 Language Pack: English,02 Uk SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355718027423928 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Repair sd Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 4.344 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-133_355718027423928_SD.RPL" missing NPC data. Certificate programmed successfully ! scan Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35571802742392-8 Product Code: 0537289 ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 ApeVariant: V 4.0839.42.2.1-08 27-09-2008 RM-133 Language Pack: English,02 Uk SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355718027423928 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF super sd auth Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized :)! warning: SD authorized but verify failed ! help plz |
Same here what is this plz check this bug mr.maole |
i'm in same problem.please help |
Is there help ??????????? |
Write modified PM only [1] and [309] area with SX4 |
I have the same bro and contact service sx4 not works in this case and i have Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 94.43.24.115 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35571802742392-8 Product Code: 0529607 ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 ApeVariant: V 4.0839.42.2.1-08 27-09-2008 RM-133 Language Pack: English,02 Uk SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355718027423928 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 41.237.18.173 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request :confused::confused::confused::confused::confused: :confused::confused::confused::confused::confused: |
ya need good suggution Br Mahadi |
Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SECURITY_TEST failed! SIMLOCK_DATA corrupted! plz help me |
MR / Manoli We are waiting a solution |
@galal777 You can make easy this phone ... backup certificates, backup PM 308 ( you will have now IMEI and SimLock+SuperDongle data stored for next actions ) ... erase NPC, write any good working PM file from N73 ( RM-133 ) . Restart phone in any mode ( for example Local -> Test -> Local ) and write back PM308. Restore NPC. Flash to desired version ( latest is good choice ) with marked downgrade option ... All be fine! ... |
SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! what i can do |
