02-03-2010, 14:22 | #1 (permalink) |
Insane Poster Join Date: Aug 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 325029 Status: Offline Thanks Meter: 8 | SECURITY_TEST failed! After Repair sd Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35571802742392-8 Product Code: 0537289 ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 ApeVariant: V 4.0839.42.2.1-08 27-09-2008 RM-133 Language Pack: English,02 Uk SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355718027423928 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Repair sd Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 4.344 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-133_355718027423928_SD.RPL" missing NPC data. Certificate programmed successfully ! scan Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35571802742392-8 Product Code: 0537289 ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 ApeVariant: V 4.0839.42.2.1-08 27-09-2008 RM-133 Language Pack: English,02 Uk SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355718027423928 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF super sd auth Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... SUPERDONGLE authorized ! warning: SD authorized but verify failed ! help plz |
The Following User Says Thank You to galal777 For This Useful Post: |
02-03-2010, 15:03 | #6 (permalink) |
Freak Poster Join Date: May 2008
Member: 783324 Status: Offline Thanks Meter: 15 | I have the same bro and contact service sx4 not works in this case and i have Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 94.43.24.115 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
02-03-2010, 15:04 | #8 (permalink) |
Member: 325029 Status: Offline Thanks Meter: 8 | Phone Type: RM-133 (Nokia N73) SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35571802742392-8 Product Code: 0529607 ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133 ApeVariant: V 4.0839.42.2.1-08 27-09-2008 RM-133 Language Pack: English,02 Uk SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 355718027423928 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 41.237.18.173 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
02-03-2010, 15:22 | #10 (permalink) |
Freak Poster Join Date: Dec 2007 Location: colombo Age: 40
Member: 645987 Status: Offline Sonork: 100.1612601 Thanks Meter: 112 | Restarting phone ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SECURITY_TEST failed! SIMLOCK_DATA corrupted! plz help me |
02-04-2010, 06:52 | #13 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | @galal777 You can make easy this phone ... backup certificates, backup PM 308 ( you will have now IMEI and SimLock+SuperDongle data stored for next actions ) ... erase NPC, write any good working PM file from N73 ( RM-133 ) . Restart phone in any mode ( for example Local -> Test -> Local ) and write back PM308. Restore NPC. Flash to desired version ( latest is good choice ) with marked downgrade option ... All be fine! ... |
02-04-2010, 06:56 | #14 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | Quote:
Guljee | |
02-04-2010, 07:01 | #15 (permalink) | |
No Life Poster Join Date: May 2008 Location: amman
Member: 764174 Status: Offline Thanks Meter: 259 | Quote:
SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! what i can do | |
6120 after repair sd security test failed problem solved... | rickliew | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 04-08-2010 09:25 |
After Repair SD SECURITY TEST failed 10000000% ok | rahman | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-07-2010 21:03 |
5130c SECURITY_TEST failed! after Repair SD | ZubairArain | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-04-2010 18:30 |
n72 help after repair sd security test failed problem | akt007 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-04-2010 10:20 |
plz help E66 after repair SD SECURITY FAIL | AswanX | Nokia Base Band 5 ( BB-5 ) | 7 | 01-21-2010 09:04 |
