02-04-2010, 10:12 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: gujarat ind
Member: 773986 Status: Offline Thanks Meter: 52 | n72 help after repair sd security test failed problem Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 05wk07v48.2 04-10-07 RM-180 (c) Nokia. ApeCoreSw: V 5.0819.4.0.1 07-05-08 RM-180 (C)Nokia SYSTEM ASIC ID: 000000010000022600010006000C192101012200 [RAP3G ver: 3.01] ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SUPERDONGLE using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 8.859 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-180_3557210233xxxxxx_SD.RPL" Updating SUPERDONGLE_KEY ...OK Phone Type: RM-180 (Nokia N72) SW Version: V 05wk07v48.2 04-10-07 RM-180 (c) Nokia. Imei plain: 35572102337038-2 Product Code: 0531463 ApeCoreSw: V 5.0819.4.0.1 07-05-08 RM-180 (C)Nokia ApeVariant: 5.0819.4.0.1-Russian 07-05-08 RM-180 (c)Nokia. Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! "RM-180" folder created. Imei net: 355721023370382 Version: SIMLOCK SERVER VERSION 58 Provider: Hutchinson 3G (3), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN, DATA=23420F BLOCK 2: 1=OPEN, DATA=23594F BLOCK 3: 1=OPEN, DATA=23420F BLOCK 4: 1=OPEN, DATA=23594F |
Successfully Repaired 3110c Security Test failed after SD Repair | romeoluv56 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 05-14-2012 12:37 |
after unlock e63 security test failed | Likom | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 05-25-2010 17:41 |
6120 after repair sd security test failed problem solved... | rickliew | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 04-08-2010 09:25 |
After Repair SD SECURITY TEST failed 10000000% ok | rahman | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-07-2010 21:03 |
plz help E66 after repair SD SECURITY FAIL | AswanX | Nokia Base Band 5 ( BB-5 ) | 7 | 01-21-2010 09:04 |
