02-28-2010, 12:37 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: egypt Age: 39
Member: 150857 Status: Offline Thanks Meter: 31 | SECURITY_TEST failed! e71 after unlock Imei plain: 35420803834728-3 Product Code: 0569999 ApeCoreSw: 100.07.76 ApeVariant: 100.07.76, ApeTest: RM346ENO74110842.a33 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 354208038347283 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-28-2010, 12:44 | #2 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | Quote:
write modified pm with sx4 | |
02-28-2010, 12:52 | #3 (permalink) |
Member: 150857 Status: Offline Thanks Meter: 31 | Completed in 52.953 s Scanning local SX4 Card ... No SX4 Card found. Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY-SX4 ver 2.5(ID), hello 196.7 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
The Following User Says Thank You to karemriko For This Useful Post: |
02-28-2010, 12:53 | #4 (permalink) |
Banned Join Date: Oct 2009 Location: Inside Digital GSM Age: 35
Member: 1149774 Status: Offline Sonork: 0313-9541047 Thanks Meter: 1,163 | bro check http://forum.gsmhosting.com/vbb/showthread.php?t=920409 If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!". This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...). Solution 1 (easy way, maybe not work all time, depends how phone was damaged): - write full PM from SAME phone model (product number) WITHOUT fields 1, 308, 309 (and WITHOUT field 120 for SL20 based phones) - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 if still have problems, use Solution 2: - backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL - backup RPL from another working phone (same model) with SAME product code - edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL - backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM - full erase flash chip (use erase file regarding flash chip size) - flash phone (CMT, APE, ...) - upload CLONE RPL - upload ORIGINAL RPL - write full CLONE PM without fields 1,120,308,309 - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 Manole (¨`·.·´¨) `·.¸(¨`·.·´¨) Keep (¨`·.·´¨)¸.·´ Smiling! `·.¸.·´ Gsm_3GN |
The Following User Says Thank You to gsm_3gn For This Useful Post: |
02-28-2010, 13:10 | #5 (permalink) |
02-28-2010, 13:12 | #6 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
02-28-2010, 13:20 | #7 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: RMS- CLUB
Member: 723410 Status: Offline Sonork: 📱 100.1592732 Thanks Meter: 3,374 | Quote:
1 unlock again 2 repaire SD... 3 write pm with sx4...cable should fine | |
02-28-2010, 13:35 | #8 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: Afghanistan 0093786144898 Age: 37
Member: 938983 Status: Offline Sonork: 100.1585802 Thanks Meter: 102 | Quote:
2: Service>IMEI & Security>Simlock>Make Simlock RPL> Update Splock 3: IMEI Rebuild>Repair SD 4: PM>Super SD Auth NOTE: when it is done successfully write a modified pm if show error try and try again until it shows done 5: IMEI & Security>Repair Simlock>Update SPlock This solution is 100% tested | |
02-28-2010, 13:50 | #9 (permalink) | ||
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | SECURITY_TEST failed! Quote:
bro problem is only now SECURITY_TEST failed! not simlock no need update simlock Quote:
WRITE MODIFIED PM FILEDS 1&309 n post results u can check here LInk br; akashub | ||
02-28-2010, 14:32 | #10 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Quote:
hello dear always use unlock by cod >> calc nck now your fone is on super dongel and here is guide (bb5>>sevice>>imei&securty>>imei rebold>>backup rpl all section>> repair sd ) now go to pm section only super sd auth betan clik now selact>> pm lord from file>>pm auth>> write pm now your fone is ok insha**************** | |
The Following User Says Thank You to naveedbutt For This Useful Post: |
E71 After Unlock Security Test Fail | Bonga_2010 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 03-13-2010 18:51 |
e71 after unlock become auto off | ahmad5175 | Nokia Base Band 5 ( BB-5 ) | 12 | 12-24-2009 15:16 |
e71 after unlock contact service provider | serdar1985 | Universalbox | 3 | 07-29-2009 01:45 |
nokia N95 8GB phone start-up failed problem after unlock with zuela | samirtelecom | Nokia Base Band 5 ( BB-5 ) | 5 | 04-29-2009 14:50 |
SC Support are you going to help with L6 etc call failed problem after unlock | pearsonjohnboy | Smart-Clip | 1 | 02-14-2006 16:51 |
