Old 09-14-2011, 08:57   #1 (permalink)
Member: 767783
Thanks Meter: 37
Arrow Nokia 1616 flashing Error
mx.. log....
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921.60 Kbps
Flash ID: 00EC 227A [Samsung ]
Processing file: rh125_006.510
Downloading item CODE:hw_f11_rh125_r06.510.fls, num block: 3, size: 4.14 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 58.125 s
Erasing area 0x00C60000-0x00E72C7E ...OK
Programming completed in 58.672 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.187 s
Checksum mismatch: Phone calculated 0x41EB, software calculated 0x31F6
Processing file: rh125_006.51mg
Downloading item CUST:hw_f11_rh125_006.51mg.fls, num block: 1, size: 1.90 MB
Erasing area 0x00210000-0x003F6C3E ...OK
Programming completed in 53.765 s
Checksum mismatch: Phone calculated 0x0A95, software calculated 0xC44A
Processing file: rh1250_nai06.51mg
Downloading item CUST:hw_f11_rh1250_nai06.51mg.fls, num block: 1, size: 419.20 KB
Erasing area 0x00EB0000-0x00F17FBE ...OK
Programming completed in 11.546 s
Checksum mismatch: Phone calculated 0x36C7, software calculated 0x550C
Total time for flashing process(boot+erase+write) was 4 min 15.234 s
plese mx..key team ... help me.... thnxxx...
Old 09-14-2011, 09:17   #2 (permalink)
Registered User
Member: 865598
Sonork: 100.1609492
Thanks Meter: 465
Using device: HTI BOX, FW ver: 00.17
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
Processing file: rh125_006.200
Downloading item CODE:hw_f11_rh125_r06.200.fls, num block: 3, size: 4.10 MB
Programming completed in 1 min 3.234 s
Erasing area 0x00C60000-0x00E6983E ...OK
Programming completed in 1 min 2.766 s
Programming completed in 0.203 s
Checksum verified (0x02AD)
Processing file: rh125_006.20ia
Downloading item CUST:hw_f11_rh125_006.20ia.fls, num block: 1, size: 1.98 MB
Erasing area 0x00210000-0x0040AC7E ...OK
Programming completed in 1 min 3.562 s
Checksum verified (0x69E5)
Processing file: rh1250_nai06.20ia
Downloading item CUST:hw_f11_rh1250_nai06.20ia.fls, num block: 1, size: 358.89 KB
Erasing area 0x00EB0000-0x00F08E7E ...OK
Programming completed in 10.484 s
Checksum verified (0x5A49)
Total time for flashing process(boot+erase+write) was 4 min 37.469 s
Phone type: RH-125
SW version: V 06.20 01-12-10 RH-125 (c) Nokia
Imei plain: 35595204378201-3
Product code: 0588620
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: IA
Language Pack:
English,Arabic,Farsi,French,Urdu
Imei net: 3559xxxxxxxxxxxxx
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 09-14-2011, 09:18   #3 (permalink)
Registered User
Member: 865598
Sonork: 100.1609492
Thanks Meter: 465
Bro Chak my post same flash try again bro okzzzzzzzzzzzzzzz
Old 09-14-2011, 13:14   #4 (permalink)
Tarikul Islam's Avatar
Member: 1310148
Sonork: 100.1601928
Thanks Meter: 293
mx.. log....
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
Check on Hardare
It is hardware fault
Old 09-15-2011, 17:48   #5 (permalink)
KKBaruah's Avatar
Member: 1540165
Sonork: 100.1606502
Thanks Meter: 29
mx.. log....
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
Try with avoidng SAFE and FAST flashing option.
Old 09-16-2011, 09:23   #6 (permalink)
Registered User
Member: 865598
Sonork: 100.1609492
Thanks Meter: 465
Bro use letest setup try again Bro link Blue-Nokia.com by Obnoxy try
Old 09-16-2011, 19:02   #7 (permalink)
atif ikram's Avatar
Member: 1644460
Thanks Meter: 44
the problem light ic or in display ( lcd or display ic) frist work on hardware
Old 09-17-2011, 07:44   #8 (permalink)
Registered User
Member: 865598
Sonork: 100.1609492
Thanks Meter: 465
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
Phone type: RH-125
Ppm Id: IA
Language Pack:
Counter: 0/3, 0/10
Page generated in 0.24351 seconds with 9 queries
