03-12-2010, 07:35 | #31 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
have u tried all the tricks posted in post#1 if yes than upload RPL here will check and tell u thanx | |
03-12-2010, 07:36 | #32 (permalink) | |
press check certificate button and upload logs here thanx | |
03-12-2010, 07:46 | #33 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | i have the same problem with 6086 here is my log with certification validation test! Quote:
03-12-2010, 08:22 | #38 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | Quote:
Guljee | |
03-12-2010, 09:30 | #42 (permalink) |
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | add me in ur messenger will solve ur problem through team viewer |
The Following User Says Thank You to hasnain For This Useful Post: |
03-12-2010, 09:53 | #45 (permalink) | |
Freak Poster Join Date: Dec 2006
Member: 407770 Status: Offline Thanks Meter: 19 | Quote:
Section: 308 Warning: failed to write 308 - 0 (1 bytes) Warning: failed to write 308 - 1 (8192 bytes) Warning: failed to write 308 - 2 (1 bytes) Warning: failed to write 308 - 3 (1 bytes) Warning: failed to write 308 - 4 (1 bytes) Warning: failed to write 308 - 5 (10 bytes) Warning: failed to write 308 - 6 (1 bytes) Warning: failed to write 308 - 7 (1 bytes) Warning: failed to write 308 - 8 (1 bytes) Warning: failed to write 308 - 9 (40 bytes) Here is RPL backup and PM: | |
The Following User Says Thank You to zeljko_c For This Useful Post: |
N73 security test fail start up fail | mobile_mania | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 31 | 03-14-2013 19:33 |
succes full repair phone startup failed and security test failed | jagdish puri | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 03-12-2010 14:17 |
Success two security TEST failed but faile in one 5220 FAILE | khokonhajigonj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 02-09-2010 15:38 |
3110C security test fail after sd repair now tested ok | GSMaxx | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-06-2010 11:19 |
Please HELP security test -Failed | rakishi | Universalbox | 0 | 01-18-2007 23:45 |
