12-08-2010, 10:41 | #1 (permalink) |
Freak Poster Join Date: Nov 2009 Location: Dubai
Member: 1172242 Status: Offline Sonork: helpfull_hkt Thanks Meter: 70 | Successfully Flash NOKIA C1 RM-689(X-GOLD) With MX-Key Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Changing baudrate to: 921600 Sending Secondary Boot Loader ...OK BootloaderString: SE0_091125 F11 Boot mode: CC EBL version: 10.13, Default_RAM_Bootloader Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] Processing CODE:hw_s01_rm689_r02.600.fls from file rm689_002.600 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 41.593 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 40.703 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.046 s Checksum OK (0x9AAF) Processing CUST:hw_s01_rm689_002.60ia.fls from file rm689_002.60ia Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 41.047 s Checksum OK (0xE090) Processing CUST:hw_s01_rm6890_nai02.60ia.fls from file rm6890_nai02.60ia Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 6.609 s Checksum OK (0xCB24) Flashing completed in 2 min 57.235 s Phone Type: RM-689 SW Version: V 02.60 06-08-10 RM-689 (c) Nokia Imei plain: 35379404498269-3 Product Code: 059B341 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35379404498269 Version: Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.\OPEN 4.OPEN 5.OPEN |
The Following 6 Users Say Thank You to helpfull_hkt For This Useful Post: |
12-08-2010, 10:46 | #2 (permalink) |
Member: 1172242 Status: Offline Sonork: helpfull_hkt Thanks Meter: 70 | Other one Successfully Flash NOKIA C1 RM-689(X-GOLD) With MX-Key Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Changing baudrate to: 921600 Sending Secondary Boot Loader ...OK BootloaderString: SE0_091125 F11 Boot mode: CC EBL version: 10.13, Default_RAM_Bootloader Flash ID: 00EC 2254 [Samsung K8S6415ETC,64 Mbits] Processing CODE:hw_s01_rm689_r02.600.fls from file rm689_002.600 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 35.859 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 35.250 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.047 s Checksum OK (0x9AAF) Processing CUST:hw_s01_rm689_002.60ia.fls from file rm689_002.60ia Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 35.063 s Checksum OK (0xE090) Processing CUST:hw_s01_rm6890_nai02.60ia.fls from file rm6890_nai02.60ia Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 5.531 s Checksum OK (0xCB24) Flashing completed in 2 min 45.297 s Phone Type: RM-689 SW Version: V 02.60 06-08-10 RM-689 (c) Nokia Imei plain: 35379404499397-1 Product Code: 059B341 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35379404499397 Version: Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
12-12-2010, 14:16 | #5 (permalink) |
Member: 1172242 Status: Offline Sonork: helpfull_hkt Thanks Meter: 70 | Successfully Flash NOKIA 2710c RM-586 With MX-Key just 34.031 s Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_358294034329 42_BACK.rpl). Processing MCU file: rm586__09.67.mcusw [BB5,XSR 1.6] size: 24.65 MB Supported Ids: 2200050920030000, 22000509200C0000 Battery voltage: 3783 mV Warning battery voltage is less, phone might not detected after flash ! Phone type: RM-586 Product code: 0589855 SW version: V 06.13 09-04-10 RM-586 (c) Nokia LanguagePkg version: V 06.13 09-04-10 RM-586 (c) Nokia MEC Version from phone: 06.13 Version from file: 09.67 Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2F27ED77 CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: -] CMT EM0 ID: 00005361 CMT PUBLIC ID: 320488850FF032C1530BA09DABD1063E3B0E0AE4 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: bcm21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: bcm21351_xsr16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Pooling for ADL device OK. Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2F27ED77 Verifying communication to device OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_358294034329 42_CERT.rpl" CMT PAPUBKEYS HASH: 84CDC75F79F52BBAE46EA3A70C9240861412C480 Storing certificate [NPC, CCC, HWC, RND, R&D] ... Partitioning.... Partitioning complete Erase size: 31.88 MB Flash programming ... CMT PAPUBKEYS: 84CDC75F79F52BBAE46EA3A70C9240861412C480 (RAP Certificate 195 v.1) written. Programming completed in 5.125 s Processing PPM file: rm586__09.67.ppm_mec [BB5,XSR 1.6] size: 4.50 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 6.50 MB Flash programming ... Programming completed in 0.906 s Processing CNT file: rm586__09.67.image_mec_black [BB5,XSR 1.6] size: 11.16 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 77.31 MB Flash programming ... Programming completed in 2.359 s Total time for flashing process(boot+erase+write) was 16.016 s Pooling for ADL device ... Device found: nmwcdc\Nokia 2710 Navigation Edition USB Phonet, ID: 3460A81A Verifying communication to device OK. Flashing completed in 34.031 s Phone Type: RM-586 (Nokia 2710c-2) SW Version: V 09.67 09-08-10 RM-586 (c) Nokia Imei plain: 35829403432942-2 Product Code: 0589855 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358294034329422 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000002 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.187 s |
The Following User Says Thank You to helpfull_hkt For This Useful Post: |
12-16-2010, 09:58 | #6 (permalink) |
Member: 1172242 Status: Offline Sonork: helpfull_hkt Thanks Meter: 70 | Successfully Flash NOKIA 5800 RM-356 With MX-Key Version from phone: ICPR72_10w21.3 Version from file: 51.0.006 Using device: POTATO BOX, FW ver: 01.B6 Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35378104883089_BA CK.rpl). Processing MCU file: RM-356_51.0.006_prd.core.C00 [BB5,XSR 1.5] size: 110.08 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Skipped by user request (flashing option). Processing PPM file: RM-356_51.0.006_prd.rofs2.V02 [BB5,XSR 1.5] size: 24.56 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1DC0000721A000524C088FA4F0AB7750CC4CE83F ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,CMT ExtBUSC: 2E20 2020 2020 2020 2020 2010 0000 0000 TransmissionMode: 16Bit Flash ID not supported for this loader (RAPIDOv11_algo.fg) Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 TransmissionMode: DDR&TX2 CMT MuxOneNAND area [07180000-0915FFFF] Erase size: 31.87 MB CMT section, erased in 0.203 sFlash programming ... Programming completed in 1 min 38.969 s Processing PPM file: RM-356_51.0.006_C01_prd.rofs3.fpsx [BB5,XSR 1.5] size: 1.23 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1DC0000721A000524C088FA4F0AB7750CC4CE83F ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,CMT ExtBUSC: 6E6F 8799 DE17 E33E 0DFC 172F C4B8 9DDD TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 TransmissionMode: DDR&TX2 CMT MuxOneNAND area [09160000-09E5FFFF] Erase size: 13.00 MB CMT section, erased in 0.125 sFlash programming ... Programming completed in 5.656 s Processing CNT file: RM-356_51.0.006_026_000_U01.uda.fpsx [BB5,XSR 1.5] size: 7.09 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1DC0000721A000524C088FA4F0AB7750CC4CE83F ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,CMT ExtBUSC: 6E6F 8799 DE17 E33E 0DFC 172F C4B8 9DDD TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 TransmissionMode: DDR&TX2 CMT MuxOneNAND area [09E60000-0F71FFFF] Erase size: 88.75 MB CMT section, erased in 0.437 sFlash programming ... Programming completed in 28.187 s Total time for flashing process(boot+erase+write) was 2 min 39.485 s Flashing completed in 2 min 51.547 s Phone Type: RM-356 (Nokia 5800 XpressMusic) SW Version: V ICPR72_10w21.3 23-06-10 RM-356 (c) Nokia Imei plain: 35378104883089-5 Product Code: 0574324 ApeCoreSw: V 51.0.006 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353781048830895 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
12-16-2010, 15:46 | #8 (permalink) | |
Member: 1172242 Status: Offline Sonork: helpfull_hkt Thanks Meter: 70 | i use Dits Cable For C1 Quote:
http://forum.gsmhosting.com/vbb/f575...1/#post6297490 | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
