Old 12-16-2012, 10:29   #1 (permalink)
praji's Avatar
Member: 563648
Sonork: 100.1594523
Thanks Meter: 87
5310 auto off in 10min
Nokia 5310 Auto Off In 10min Then Blue Screen
Flash With Latest Vershion
No Board Water Damage
Remove speaker
Change Steel Frame
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C085E9AF
Using device: HTI, FW ver: 00.50, SN: 0000E7D4
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101013000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 29F00114F864025460DB67492A7176400A94D736
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 3E96DE4212587183E5E16BB2C79692A53C19875D
TransmissionMode: DDR&TX2
Selected firmware certificate matched.
Original Imei: 35956201268361
Original Product code: 0557203
Bluetooth ID: 001E3B412149
SIMLOCK PA identifier:
[0] PA_SL2
Phone type: RM-303 (Nokia 5310 XpressMusic)
SW version: V 09.42 07-11-08 RM-303 (c) Nokia
Imei plain: 35956----------
Battery voltage: 4767 mV, current: 14 mA
Language Pack:
- not available.
SLPA ver[2]: PA_SL2 (15 digit NCK)
Camera config: NIMMIIIIRRFF06150018, ver: 002.005
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 359------------
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Self Test
Phone Type: RM-303
ID Test name Startup Result
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
15 SLEEP_X_LOOP Y passed
46 UEM_CBUS_IF Y passed
7 KEYBOARD_STUCK N passed
22 CAMERA_IF N passed
43 LCD N passed
21 LPRF_IF N !not ready
44 LPRF_AUDIO_LINES N !not ready
2 CURRENT_CONS N !not ready
42 RADIO Y passed
69 BACKLIGHT Y passed
33 SIM_LOCK N passed
93 SECURITY N passed
71 BT_WAKEUP N !not ready
96 HOOKINT N !not ready
88 TAHVOINT Y !not ready
56 SLEEPCLK_FREQ N passed
101 BTEMP N passed
107 BT_SLEEP_CLK N !not ready
32 AMB_LIGHT_SENSOR N !not ready
119 IIC N !not ready
108 EXT_DEVICE N passed
86 CDSP_RF_BB_IF N passed
83 CDSP_RF_SUPPLY N passed
80 CDSP_TX_PLL_PHASE_LOCK N passed
81 CDSP_RX_IQ_LOOP_BACK N passed
77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03)
What This Problem ?????????????????
Old 12-16-2012, 11:20   #2 (permalink)
VC_INDIA's Avatar
Member: 1236722
Sonork: 100.1601546
Thanks Meter: 4,180
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
All Logs Is valid
Now tack Action u take Backup rpl or
u need to full erase flash set then restore rpl
THen Check set an post result.
Vikash
Old 12-16-2012, 14:36   #3 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Hi,
Logs seems to be OK,
Try change LCD & Camera,
If not solve, then try to Erase Phone,
Step here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/
BR,
ZUBER
Old 12-16-2012, 16:01   #4 (permalink)
praji's Avatar
Member: 563648
Sonork: 100.1594523
Thanks Meter: 87
Originally Posted by .::ZUBER::. View Post
Hi,
BR,
ZUBER
Change Display And Remove Camera But No Luck
Few min Automatic Going To Hang On Blue Screen
Old 12-16-2012, 17:37   #5 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
It's Hardware Problem 100% Combo IC Inside Shortage.
BR.
Arsalan gsm2000.
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post:
Old 12-16-2012, 17:56   #6 (permalink)
praji's Avatar
Member: 563648
Sonork: 100.1594523
Thanks Meter: 87
BR.
Arsalan gsm2000.
When I Backup Simlock Data,Read PM Very slow To Read
Sometime Need To 2 Or 3 Times Want To Press ( Automatic Going From Local Mode )
Other Mobile Flashing And All Function Ok In Mx
Old 12-16-2012, 20:28   #7 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Even if your PCB looking fine then also Waterlogged, may be.
Check properly with Magnifying Glass, whether Display Connector damaged with Water,
Many times resolve this type of problem.
BR,
ZUBER
Old 12-17-2012, 16:41   #8 (permalink)
Member: 581023
hw problam okkkkkkkkkkkk
Old 12-18-2012, 19:18   #9 (permalink)
praji's Avatar
Member: 563648
Sonork: 100.1594523
Thanks Meter: 87
Hi,
BR,
ZUBER
BR.
Arsalan gsm2000.
Bro.
BR,
ZUBER
Combo IC Problem When Little Heat On IC Working After Same
Little Shake Now OK
Thanks For Support
Page generated in 0.20881 seconds with 8 queries
