Old 10-16-2009, 07:45   #1 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
Arrow MX-Key Logger Ate My Last 10 Credits!
Hi MX-Key Team!
It is really a surprise for me. I had 10 credits left. So thought to use it. Everything went fine but instead of giving me a RPL, server replied - Credits Left - 0 without RPL.
Here is log:
ASIC ID: 0x2201 [UPP_2M ver: 2]
 SecondaryBoot: u_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0
 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x7518
Performing Flash Authentication ...OK
UEM ID: 004702B9:2984DA60
ASIC type: 2
UEM Imei: 35327201620549
Connecting to server ...OK, Login ...
Hello C0800049, you have 0 credits left.
Registered to Azeemuddin
Serial : C0800049
Reseller : mobileclinic
I think there is any bug in processing last credit.
Anyway out there to refund?
Br,
Shadab Ahmad
Old 10-16-2009, 09:09   #2 (permalink)
Member: 81931
Thanks Meter: 92
may be u forgot ? or some other your worker , staff using it ????
u can go in support area refer back the last credit used .
Old 10-16-2009, 09:41   #3 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
I check it in Support Area. My last IMEI, for which I was going to use it, is listed there.
But the problem is, after showing that my credit is 0, the process stopped and not received RPL file.
May be this is bug in MX-Key software so when credit is reached 0, logger will stop transaction with server, thus not receiving RPL.
Br,
Shadab Ahmad
mx-key logger problem lukylike_102 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 11-27-2009 06:11
MX-key Logger... always says PRIVILedge instructions -=whitezaNder=- MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 11-14-2009 05:00
Need help for mx key logger parihar MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 10-22-2009 07:51
MX-Key Logger Problam (winsock error: Connection refused) rajinder1978 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 07-30-2009 21:35
Page generated in 0.14965 seconds with 9 queries
