Old 01-28-2010, 19:33   #1 (permalink)
leonize's Avatar
Member: 1096162
Thanks Meter: 411
superdongle corrupt
Backup already exist.
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11893, Date: 26-01-2010
Product: V 07.23 17-07-09 RM-410 (c) Nokia
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK
Sending PreLoader(0x2E4 bytes) ...OK
Sending CustomLoader(0x596C bytes) ...OK
Calculating RPL using security server ...
Connecting to server[main.mxkey.biz] ...OK, Secure Login ...
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_355746020933569_SIM.RPL"
Updating SIMLOCK...OK
Reading Simlock info ...
Imei net: 355746020933569
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
remove the contact servce after 2 attempts at the end to fix it and gives me all the information so good worst team every 3 minutes the computer restarts, do not stop and find that it is the corrupt superdongle
Imei: 35574602093356
Restoring RF/BB DATA from backup ...
Updating RF ...OK
Updating BB ...OK
Updating WARRANTY ...OK
Updating PROD ...OK
Updating BT ...OK
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 25C0010998DD5550CFA2901658C43663628148A5
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: D93826B23E9B093BE4DD7304FBAA6778996AE60B
NPC verified Ok.
Updating CMT NPC ...OK
Updating CMT CCC ...OK
Updating CMT HWC ...OK
Updating PRODUCTCODE (0568827)... OK
Updating HWID (0568)... OK
Updating SIMLOCK...Trying to update SUPERDONGLE_KEY ...error 0x0
Updating WMDRM_PD...OK
Certificate programmed successfully !
Phone Type: RM-410 (Nokia 5220 XpressMusic)
SW Version: V 07.23 17-07-09 RM-410 (c) Nokia
Imei plain: 35574602093356-9
Product Code: 0568827
any solution to this?
Old 01-28-2010, 19:38   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
we can't repair that.
at moment we can repair SIMLOCK DAMAGE except SL3.
closed,
already many time answer.
and never searching first.
br,
question about superdongle data of n-95 8gb compue Universalbox 2 03-29-2010 15:16
Calculating SUPERDONGLE with corrupted IMEI feilikesi Cyclonebox 3 03-14-2010 13:13
superdongle cant repair on cyclone [Superdongle rebuild not supported] zunair Cyclonebox 1 01-08-2010 10:55
No Superdongle data exists, you need to generate Superdongle data SYRYA TEL Universalbox 3 12-02-2009 11:38
Howto Repair SuperDongle dadang.haryadi Nokia Base Band 5 ( BB-5 ) 0 06-20-2009 06:53
Page generated in 0.13166 seconds with 9 queries
