02-25-2010, 11:55 | #1 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 812422 Status: Offline Thanks Meter: 18 | is there any salution for this SW Version: V 06.94 21-07-09 RM-495 (c) Nokia Imei plain: 35932902904444-3 Product Code: 0571584 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! |
02-25-2010, 12:44 | #5 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 470292 Status: Offline Thanks Meter: 147 | Already discussed.... see below.... 1. SuperDongle Repair 2. Security Test Failed 1. SUPERDONGLE REPAIR SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed in this case a.press repair Super Dongle b.than SD Auth PM c.than good pm including fields pm1 and pm309 2. SuperDongle repair (case2) SIMLOCK passed! SUPERDONGLE_KEY passed! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed a.press repair Super Dongle b.than SD Auth PM c.than good pm including fields pm1 and pm309 3. Security test Failed SIMLOCK passed! SUPERDONGLE_KEY passed! SIMLOCK_TEST passed SECURITY_TEST failed in this case no need to full erase than flash just in few steps u can do this a. first of all Do SX4 than PM1 and PM309 if no success than b. replace CCC and HWC cert of RPL from same model and write it back to ur phone than repeat the SX4 + pm process hope this will help u to sort out such errors SUPERDONGLE_KEY ...error 0x0 simply make simlock rpl than write simlock rpl than sd than pm if still than recover cert than sd than pm if still facing such error on N95 8GB or other models than contact me will do it for u |
02-25-2010, 13:23 | #7 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 405696 Status: Offline Thanks Meter: 148 | NOT SUPPORTED FOR UNLOCK LIST RAPUYAMA v1.11 PR_RTSA_BGA401/CSP - PA_SL3 Security 5630d (RM-431) 6720 Navigator (RM-491) 6700 Classic (RM-470) 6720 Classic(RM-424) 6730 Classic (RM-547) 6730 Classic (RM-566) 7020a (RM-497) E52 (RM-469) E55 (RM-482) E72 (RM-529) E72 (RM-530) RAPIDOYAWE 1.13E - PA_SL3 Security 5730s (RM-465) 5530 (RM-504) 5800d (RM-356) - v10.4.016 with HASH: 479C6DDE3942E12C429C1D6ADED80371 N97 (RM-505/506/507/555) RAPS_V3.03/3.02 - PA_SL3 Security 2700 Classic (RM-561) 2730 Classic (RM-578) 2730c-1b (RM-579) 3600 Slide (RM-352) v56.26 - v57.23 3720 Classic (RM-518) 5130 XpressMusic (RM-495) 5310 XpressMusic (RM-303) v58.58 - v59.42 6202 Classic 6300 (RM-217) v57.20 6303 Classic (RM-443) 6500 Slide (RM-240) v59.60 6500 Classic (RM-265) v59.45 7610 Slide (RM-354) v57.23 RAP3GS2 v4.1/4.11_C021 - PA_SL3 Security 3710a-1 (RM-509) 3710a-1b (RM-510) 3711a-1 (RM-511) RAPS2 v4.1/4.11 - PA_SL3 Security X3 (RM-540) X6 (RM-559)br, |
The Following User Says Thank You to Ramzan khan For This Useful Post: |
is there any solotuion for this cpu | c_ahmad79 | CPF-BOX Ⅱ | 11 | 01-09-2009 15:22 |
sir is there any solotuion for this problem...? | c_ahmad79 | BB5KING for (BB5BOX) | 11 | 11-12-2008 14:05 |
Raskal,Is there any moderator for this section? | gsmsalers | JAFWM | 1 | 04-24-2007 22:41 |
Is There Any Site For This Dongle ? | TWISTER_FLasher | FuriouS II | 1 | 10-28-2004 00:09 |
Is there any reason for this action.... | Raskal | Off Topic Zone | 0 | 10-31-2002 04:04 |
