10-25-2013, 11:52 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Check with Buscheck, whether it's 15 or 20 Digits NCK, If 15 Digits NCK, then it's supported for Unlock with Mxkey. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
10-26-2013, 16:54 | #5 (permalink) |
No Life Poster Join Date: Jun 2008 Location: dunja
Member: 786607 Status: Offline Thanks Meter: 66 | Imei plain: 35863304639151-8 Product code: 0597913 Cellular system: GSM ASIC ID: 0x2292, type: 11 Ppm Id: AD Language Pack: English,French,German,Turkish Imei net: 35863304639151 Provider: T-Mobile Deutschland GmbH , Country: Germany Counter: 0/3, 0/10 CONFIG_DATA: 2620100000000000 PROFILE_BITS: 8000000000030002 BLOCK1: 1=CLOSED(MCCMNC), DATA=26201F [Germany-T-Mobile Deutschland GmbH ], 2=CLOSED(GID1), DATA=26201F [Germany-T-Mobile Deutschland GmbH ] BLOCK2: 1=CLOSED(MCCMNC), DATA=26201F [Germany-T-Mobile Deutschland GmbH ], 2=CLOSED(GID1), DATA=26201F [Germany-T-Mobile Deutschland GmbH ] Imei net: 35863304639151 Provider: T-Mobile Deutschland GmbH , Country: Germany Counter: 0/3, 0/10 CONFIG_DATA: 2620100000000000 PROFILE_BITS: 8000000000030002 BLOCK1: 1=CLOSED(MCCMNC), DATA=26201F [Germany-T-Mobile Deutschland GmbH ], 2=CLOSED(GID1), DATA=26201F [Germany-T-Mobile Deutschland GmbH ] BLOCK2: 1=CLOSED(MCCMNC), DATA=26201F [Germany-T-Mobile Deutschland GmbH ], 2=CLOSED(GID1), DATA=26201F [Germany-T-Mobile Deutschland GmbH ] how to know digits |
The Following 2 Users Say Thank You to manule For This Useful Post: |
10-27-2013, 10:17 | #6 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Your Logs is of Scan, So please click Buscheck Button will get full Logs, If want to check, don't edit & post full Logs of Buscheck. BR, ZUBER | |
10-28-2013, 15:02 | #7 (permalink) |
Member: 786607 Status: Offline Thanks Meter: 66 | MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C086FF92 Using device: HTI, FW ver: 00.50, SN: 010057F2 Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version: Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 00EC 227A - 23280002 [Samsung ] CFI information: Flash settings: 0/1, size: 0x00800000 2 Block regions: 127 x 0x00010000 = 0x007F0000 8 x 0x00002000 = 0x00010000 EBL ready ! |
