03-29-2012, 15:07 | #1 (permalink) |
Registered User Join Date: Feb 2009 Location: Craiova(Romania) Age: 18
Member: 972420 Status: Offline Sonork: manole Thanks Meter: 134 | my box mx-key cannot bus check..... (ANSWERED) ayaw mag bus check o mag connect unit,palit ko cable error pa rin po.................. ito log error.......... MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C085654A Using device: HTI, FW ver: 00.50, SN: 0000A4AB Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012) ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed! help this problem.................... |
03-29-2012, 15:21 | #2 (permalink) |
Insane Poster Join Date: Apr 2010
Member: 1283654 Status: Offline Thanks Meter: 9 | i have the same problem with a nokia c7! i mention that fbus cable is not faulty because i have tested on other handset of the same type and it is working! what could be wrong because i rehot combo flash-rapu ic but still the same? also when i try to turn the phone on the combo flash-rapu gets very hot instantly (i put finger on it) and then immediately cools itself! |
03-29-2012, 17:11 | #4 (permalink) |
Junior Member Join Date: Apr 2008
Member: 762446 Status: Offline Thanks Meter: 13 | i same problem this log with mx box green : MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0600ACF Using device: HTI, FW ver: 00.50, SN: 00000C14 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011) Boot error: 02 00 00 73 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. |
03-29-2012, 19:58 | #6 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | bro. forget it & use latest update from here: http://forum.gsmhosting.com/vbb/f550...1/#post8276268 |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
03-31-2012, 19:57 | #7 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | looks like power transistor is damaged http://forum.gsmhosting.com/vbb/f550...fault-1325626/ |
The Following User Says Thank You to gbluez For This Useful Post: |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
