03-07-2010, 16:32 | #1 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 735092 Status: Offline Thanks Meter: 17 | usb error[SOLVED by USER] Processing file: rm469_022.009_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 95.92 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1FB74BCC RAP SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 1DE00108E36C0344DFF72FCD8BAFAC3E12EA14C5 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 RAP ROM ID: 3E273BF637BE26FA [ADL] Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 9.38.1 revision: 2.1 size: 0x3A40 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] Secondary boot loaded. FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: ONENAND,RAP [ADL] Loading CMT Update Server Data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 9.38.1 revision: 2.1 size: 0x7EE22 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] Update Server code loaded. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 1FB74BCC [ADL] Verifying communication to device OK. RAP PAPUBKEYS HASH: 85F252E351E225CAFC4DFBC8041EABD2823E3500 Storing certificate OK. Partitioning.... Partitioning complete Total erase size: 64.00 KB Flash programming ... CMT PAPUBKEYS: 85F252E351E225CAFC4DFBC8041EABD2823E3500 (RAP Certificate 147 v.1) written. Programming completed in 26.594 s Processing file: rm469_022.009_11.01_MENA_B_prd.rofs2.fpsx as PPM [BB5,XSR 1.6] size: 29.45 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Total erase size: 41.75 MB Flash programming ... Programming completed in 8.046 s Processing file: rm469_022.009_U000.000_prd.uda.fpsx as CNT [BB5,XSR 1.6] size: 688.27 KB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Total erase size: 65.25 MB Flash programming ... Programming completed in 0.594 s [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. [ADL] Phone flashing completed, but failed to verify communication to product! [ADL] Retrying in finalize phase... [ADL] Pooling for ADL device |
03-07-2010, 16:36 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | r u using latest flash file or not check or use fbus cable and buss check again post result |
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post: |
03-07-2010, 16:53 | #3 (permalink) |
Member: 735092 Status: Offline Thanks Meter: 17 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Processing file: rm469_022.009_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 95.92 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 1DE00108E36C0344DFF72FCD8BAFAC3E12EA14C5 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP ExtBUSC: 7938 886C A71F D96C ACC6 4786 5F06 83CF ExtDEVC: FFFF 0000 - 0000 0000 Flash ID not supported for this loader (RAPUv11_algo_xsr16.fg) Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS is blank/erased. Storing certificate ...Error Flashing terminated with error(s) in 37.906 s RX Buffer: 0400000000B172 this is the reading in fbus |
03-07-2010, 17:01 | #4 (permalink) | |
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
03-07-2010, 17:23 | #5 (permalink) |
Member: 735092 Status: Offline Thanks Meter: 17 | Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Processing file: rm469_022.009_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 95.92 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 RAP Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 1DE00108E36C0344DFF72FCD8BAFAC3E12EA14C5 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP ExtBUSC: 3C00 4400 4500 5600 4300 4500 5200 5400 ExtDEVC: FFFF 0000 - 0000 0000 Flash ID not supported for this loader (RAPUv11_algo_xsr16.fg) Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 RAP PAPUBKEYS is blank/erased. Storing certificate ...Error Flashing terminated with error(s) in 1 min 11.500 s jaf reading |
03-07-2010, 17:41 | #9 (permalink) |
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | check here ur error solution http://forum.gsmhosting.com/vbb/showthread.php?t=726058 |
03-07-2010, 18:55 | #10 (permalink) |
Member: 735092 Status: Offline Thanks Meter: 17 | another succes story usb flashing i flash to higher version 031.012 and it succes heres the logs...thank for the reply bro... Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) Processing file: rm469_031.012_prd.core.fpsx as MCU [BB5,XSR 1.6] size: 96.89 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: CFD9B27 RAP SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 1DE00108E36C0344DFF72FCD8BAFAC3E12EA14C5 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 RAP ROM ID: 3E273BF637BE26FA [ADL] Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 9.38.1 revision: 2.1 size: 0x3A40 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] Secondary boot loaded. FlashID0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: ONENAND,RAP [ADL] Loading CMT Update Server Data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 9.38.1 revision: 2.1 size: 0x7EE22 Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 [ADL] Update Server code loaded. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: CFD9B27 [ADL] Verifying communication to device OK. RAP PAPUBKEYS HASH: 85F252E351E225CAFC4DFBC8041EABD2823E3500 Storing certificate OK. Partitioning.... Partitioning complete Total erase size: 64.00 KB Flash programming ... CMT PAPUBKEYS: 85F252E351E225CAFC4DFBC8041EABD2823E3500 (RAP Certificate 147 v.1) written. Programming completed in 27.234 s Processing file: rm469_031.012_11.01_MENA_B_prd.rofs2.fpsx as PPM [BB5,XSR 1.6] size: 31.18 MB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Total erase size: 41.75 MB Flash programming ... Programming completed in 8.734 s Processing file: rm469_031.012_U000.000_prd.uda.fpsx as CNT [BB5,XSR 1.6] size: 752.28 KB Supported RAP Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Total erase size: 65.25 MB Flash programming ... Programming completed in 0.640 s [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia E52 USB Generic, ID: B7B36C2 [ADL] Verifying communication to device OK. Flashing completed in 1 min 25.125 s Phone Type: RM-469 (Nokia E52-1) SW Version: V ICPR82_09w46.3 28-12-09 RM-469 (c) Nokia Imei plain: 35932703470944-8 Product Code: 0591683 ApeCoreSw: 031.012 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 359327034709448 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 1 min 28.375 s |
how can solve contect service 3110c[SOLVED by USER] | Abidqadeer | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-06-2010 15:34 |
MX Software Freezing[SOLVED by USER] | curtisbcm | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-04-2010 06:19 |
help..mx key show : ERROR=Invalid password.[SOLVED by USER] | xiong897 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-01-2010 06:57 |
Nokia 7310c[SOLVED by USER] | gerdzio | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-27-2010 00:35 |
