03-06-2010, 17:43 | #1 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1146326 Status: Offline Thanks Meter: 12 | when i make super sd auth and press yes to "you are about to rewrite simlock settings you want to skip" i get this, SECURITY_TEST failed! if i press no to "you are about to rewrite simlock settings you want to skip" i get this SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! SIMLOCK_DATA corrupted! so how to fix security test failed or can i leave it that way or it must be fixed ? |
03-06-2010, 17:45 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: City Center
Member: 770272 Status: Offline Sonork: 100.1603193 Thanks Meter: 227 | Quote:
1:Connect ur mobile and press scan botton. 2:Click on SERVICES. 3:Goto IMEI & SECURITY tab. 4:Click on SIMLOCK in left hand. 5:Put a tick mark in Make SIMLOCK RPL 6:and click Update SpLock Super SD Auth, then write PM1 and PM309 regarding connected phone model | |
WD timer enabled, phone will reboot itself after 3 min. ## (ANSWERED) | .::PATEL TELECOM::. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 43 | 10-02-2011 16:46 |
Nokia 3110c WD timer enabled, phone will reboot itself after 3 min | jodhpur_raj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 01-30-2010 22:59 |
WD timer enabled, phone will reboot itself after 3 min | misterG | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 01-14-2010 03:20 |
WD timer enabled, phone will reboot itself after 3 min. | ehsas_ghum | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 12-16-2009 12:11 |
WD timer enabled, phone will reboot itself after 3 min | gul_hassan528 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 09-14-2009 22:18 |
