09-27-2010, 17:40 | #1 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 197485 Status: Offline Thanks Meter: 19 | why Programming UEM Imei (OTP) ...failed SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0046B54B:2984DA60 ASIC type: 2 UEM Imei: 04414894627 SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.3 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\04414894627.R PL" ASIC ID: 0x1130 [UPP_8M ver: 3.0 or 3.01 or 3.1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0046B54B:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Programming UEM Imei (OTP) ...failed Phone Type: RH-46 (Nokia Wanda) SW Version: V P190V0500.nep 16-09-04 RH-46 (c)NMP Esn plain: 04414894627 Esn OTP: 04414894627 Product Code: 0519908 Cellular System: CDMA ASIC ID: 0x1130, type: 2 Ppm Id: L Language Pack: Indonesia,English,Chinese Simpl.,Chinese Trad. the phone turn off after 30 sec |
09-27-2010, 20:07 | #3 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | "Programming UEM Imei (OTP) ...failed" otp=one time programmable if you have empty uem then write imei only in one time after programme you can't able to write. btw if your phone have 30sec power off after rebuild imei/esn then you should change uem & reprogramme . |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
Upload / Download eeprom program for 51xx/61xx | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-07-1999 14:03 |
