03-03-2009, 19:41 | #1 (permalink) |
Junior Member Join Date: Mar 2009
Member: 985791 Status: Offline Thanks Meter: 0 | Write Back RPL Backup I only have 357xxxxxxxxxxxx_back.rpl (2.54 KB) not fully RPL backup. And when i want to restore this RPL i got this message : Operation done with error. Do i need make ASK and then request new RPL ??? No Backup PM, because friend only give the phone with not fully RPL backup. Phone info Code: Version Info: MCU SW version: V 06.60 21-05-08 RM-272 (c) Nokia. HW version: 1001 RFIC version: 17211721 DSP version: ICPR61_08w10 PPM version: V 06.60 21-05-08 RM-272 (c) Nokia. X BT MCM version: KTN L Retu version: 32 Tahvo version: 53 Content Pack version: Content: x V 06.60 21-05-08 RM-272 (c) Nokia. Serial Numbers: IMEI plain: 12345610654321? IMEI spare to net: 1A 32 54 16 60 45 23 01 IMEI SV to net: 13 32 54 16 60 45 23 21 F1 Other Info: Model : Nokia 3500c (Classic Phone) Imei: 12345610654321? Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 1/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: LOCK 1: STATE=CORRUPTED Last edited by zienau; 03-03-2009 at 19:43. Reason: add additional informations |
03-03-2009, 19:49 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
03-03-2009, 20:30 | #6 (permalink) |
Member: 985791 Status: Offline Thanks Meter: 0 | Ups, .... i'm in "LOCAL MODE" but when try to write the phone blink and shows "TEST MODE" and this message appear : Operation done with error. Last edited by zienau; 03-03-2009 at 20:36. |
03-03-2009, 20:39 | #7 (permalink) | |
JAF,MT..Please try with other box ...if still same creat error then use ASK2RPL service.. | |
03-03-2009, 20:53 | #10 (permalink) |
Member: 985791 Status: Offline Thanks Meter: 0 | using JAF, write RPL Can't decode RPL File... Write RPL with checking "Plain RPL" option Corrupted RPL File... but i'm not sure it's corrupted or not because i use another tool kurang aseeemmm!!! |
03-03-2009, 22:13 | #12 (permalink) |
Member: 985791 Status: Offline Thanks Meter: 0 | Well, here the RPL is,... hope you can help me Thanks Code: http://www.megaupload.com/?d=MNVSEK65 mirror http://www.indowebster.com/RPL_Nokia_BB5.html |
03-03-2009, 22:36 | #14 (permalink) |
Member: 985791 Status: Offline Thanks Meter: 0 | and why this imei different ??? between name of file and inside file itself ? 3576860169xxxxx can i change the imei inside file ? and it will worked or not ? Code: [SER_PROG_DATA_OUT] IMEI=350604100768200 DATA1=617CD5B1CC074BBDBFE9B093AFAC29A9B85BE17583D97BE1CDB20AC04A7FB46A7C6723179BDBF61A DATA2=B9D2663ECC04AB708454340DEFC321086139F76CBA3E403F1F73C89554B32D8EB22FBA37BE565E44AF08B71FA32116DDE36AED03FEE17DFACF9432E56B9C4157E7F6A99D722B6D1B832539FEBF1A58B30208CB2E0A4D442D CHECKSUM=20837 [SIM_PROG_DATA_OUT] IMEI=350604100768200 PRODUCTCODE=0506953 PROG_DATA_1=001010000000000000000000000000029FC258F1BA458FBA0BB110596C7AFEC7CA29B841493A64DABAA0E4432B22A302D9E7 PROG_DATA_2=9D675DA8432CA17BF0C565D25CAE2E088D063AF551F701D01665219A168128C9BD1B0726A1CEB7ABD92E4E4C4DD78051667B PROG_DATA_3=AF620A2E00A0A9B52D43963C64A379CD77C89DBA261E59E4061C18C724A7B3E5E49217BB853C39530C1E30D52107DC147962 PROG_DATA_4=3E707BC34BED2DD08D72488C296DBF7DC46563EC3EB7119DAD7B5617FBB274A918F38CA31830A5E03C30DDF4B2486A4288C3 PROG_DATA_5=A2C936830700128EED6455942C68D131ED059385F4D93FFCE6D8C358F5D8600688653F5C4369462C8E877727EBED61BFCB0D PROG_DATA_6=B24911A519FDC1A8D941BC364F922A0AB81ABC41B9A165C14769FF1D496CD1E0FFEC2CDDEBCE0CC61FD4CC7DFB4805718FC6 PROG_DATA_7=5DEC5E05092F7637065705DD58F96DAC853314EEDC32BCF4852E1EAA4F3C5DD5B594292989FB67A0EFCC9F32446D71A29D8A PROG_DATA_8=8C584F3671762CEE882C5FBD3F54230A0F1EA8A9031A51DB144D71E0D63478AD3B6831E6F0CE6FF916E3E4CF963B67E65325 PROG_DATA_9=B0A5E5AF8F033898237B0CFFBA88F7B9921E2F9AC7A13548C5279C417E4EE7052A192019E3687F093EEB02336344B989EF05 PROG_DATA_10=971F214E4676DAC819E2F240E3769C54F47BDC97A22704A37237550411CBA34ECFDBFBC24E85F2695739938053FC7FB0FBEF PROG_DATA_11=45E319983FA92B2A7BFE3098AAE6C20560CA7922CB352E7933A64AD1C25EC06B035BBB79F74880D175CF6BF3A164752C6962 PROG_DATA_12=D6B6CF9FDC9E329B566773F22B6008CDDE44FAB2018F5F21030FD0978AD790361239B35123DC620A87FE442AF44786755E74 PROG_DATA_13=95008E323D1534FD69B8E05D8AD61BF11457C2AB45E5C73703E32EDE1EB9107801251DBB3D0F2E23D1F45276CEDD2849EF89 PROG_DATA_14=DFD9788C7DD188F25DD6521649492F25623B4BE0D4E65C31B420654970996D64FBE83D1569AC95B069C134F47319E023C3B1 PROG_DATA_15=AC9016A0CB087AF906FC40E6302ADB8A724A148CB6C00C0BBE30B1873B10D0B9BC9A3937C0096617B1A51D38767EDD98D4BD PROG_DATA_16=F69A036B6F2412B8A2638B694D904B3522C5FD826157B2295EC9D93C8E31F4412809CCC2D3ADDFC3ECA3A61627BF144D02A3 PROG_DATA_17=626DA4FD33C18C255CD32422DC8F7678A610E9A7CDF74C9914877B4FF9188DE939D3863CF9925FA529EB6DA40150EBA060F4 PROG_DATA_18=4032642B5C8421AB55A41F30F661FDF833D5DD7A833D43996D20F1FE39996168BC63260BCCA469CB173FFE9DE0A784B7D56B PROG_DATA_19=45B49C8D504B62F169E03D3B108D7AF7160585CC1A8B3058D0E89F6A8283F0798333CB1B2E3A6168401DC71F3B3BD6C71095 PROG_DATA_20=016E CHECKSUM=8405 |
is ther any procedure write back rpl | taieeb | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-08-2010 07:02 |
After bad sx4 auth attempt..now cant write back security backup certificates [SOLVED] | ASHIF | Cyclonebox | 9 | 08-31-2009 17:12 |
Can't Write back the Backup RPL | torpedo_seluler | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-01-2009 06:07 |
can't write back rpl | alvis168 | Universalbox | 13 | 10-21-2008 17:17 |
BE5 v122 I can't write back my backup!! | chavrotti | Alcatel & TCL Old Models | 4 | 07-04-2003 18:32 |
