04-11-2011, 09:19 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: india
Member: 1053356 Status: Offline Sonork: 12345 Thanks Meter: 18 | x3-02 flash error (ANSWERED) when trying to flash via usb Code: Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 9539496 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 05B0011555A703443496DDDE3E0A745A5C207235 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 ERROR: Secondary boot not responding ! Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) Processing MCU file: rm639__05.65.mcusw [BB5,XSR 1.6] size: 30.64 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 05B0011555A703443496DDDE3E0A745A5C207235 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 10.32.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 New Protocol is not supported for the current interface (UFS_USB V2.8 (c) SarasSoft 2007.). Please select correct loader version from 'Config' menu ! RX Buffer: please give me a solution |
04-11-2011, 09:36 | #2 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | never flashed this type before... if u have atf, try using atf as interface or atf itself... if got no more flashing box, u can try phoenix crack... it works for new protocol, i just never tried it on x3-02... good luck bro br |
The Following User Says Thank You to specta For This Useful Post: |
04-11-2011, 13:19 | #6 (permalink) | |
Member: 1053356 Status: Offline Sonork: 12345 Thanks Meter: 18 | Quote:
when trying to flash via usb it gives the following error Code: Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 9539496 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 05B0011555A703443496DDDE3E0A745A5C207235 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 ERROR: Secondary boot not responding ! | |
04-12-2011, 20:49 | #7 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, you're using older version of mobileEx application. please visit update info more often. http://forum.gsmhosting.com/vbb/f550...pdates-685905/ - download current version, click here - do module update click here # never use any usb hub (better), plug usb flashing cable to pc port directly. # use fully charged battery, press Flash, insert cable, press pwr on if needed. # try with skip erase and fast flash tick/untick combination. # since the phone is "dead", un mark 'safe flash' BR |
04-15-2011, 09:58 | #8 (permalink) | |
Code: Library version: 1.0.0.9274(01-03-2011), 1.0.0.15868(10-03-2011) Processing MCU file: rm639__05.65.mcusw [BB5,XSR 1.6] size: 30.64 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 270425E0 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 05B0011555A703443496DDDE3E0A745A5C207235 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 ERROR: Secondary boot not responding ! | |
04-15-2011, 14:03 | #9 (permalink) | ||
No Life Poster Join Date: May 2010 Location: BaNgLaDeSh
Member: 1310148 Status: Offline Sonork: 100.1601928 Thanks Meter: 293 | Quote:
Everyone already X3 Flash done with USB successfully Quote:
http://rapidshare.com/files/45608569...29_Cracked.exe | ||
The Following 2 Users Say Thank You to Tarikul Islam For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
