02-07-2011, 12:50 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | X3-O2 RM-639 blinking problem after flashing same Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Processing MCU file: rm639__05.65.mcusw [BB5,XSR 1.6] size: 30.64 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: E3909BA CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 2A00010DB19C03444B608ED15FA342DBFCA423C8 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Pooling for ADL device OK. Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: E3909BA Verifying communication to device OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35376404094676_CE RT.rpl" CMT PAPUBKEYS HASH: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C Storing certificate [NPC, CCC, HWC, R&D] ... Partitioning.... Partitioning complete Erase size: 45.06 MB Flash programming ... CMT PAPUBKEYS: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C (RAP Certificate v1 260) written. Programming completed in 6.690 s Processing PPM file: rm639__05.65.ppm_d [BB5,XSR 1.6] size: 8.19 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 12.00 MB Flash programming ... Programming completed in 1.789 s Processing CNT file: rm639__05.65.image_d_0598107_007 [BB5,XSR 1.6] size: 31.65 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 66.06 MB Flash programming ... Programming completed in 6.832 s Total time for flashing process(boot+erase+write) was 30.242 s Pooling for ADL device ... Timeout, no usb device found. Flashing completed in 1 min 56.381 s Phone not responding ! waiting for reply br |
02-11-2011, 16:12 | #7 (permalink) |
No Life Poster Join Date: Oct 2009 Location: serbia Age: 44
Member: 1131244 Status: Offline Sonork: 100.1596724 Thanks Meter: 376 | today had the same problem,tried with all known method(usb and fbus) and boxes,result is the same,not power up after flash,my guess is bad(damaged) flash chip because in one flashing report bad blocks(addresses). |
03-01-2011, 13:58 | #9 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gujarat, india
Member: 890965 Status: Offline Sonork: 100.1605360 Thanks Meter: 180 | [QUOTE=azeem781986;6927093]Hi to all here is the log I got X3-O2 on blinking and flashed wtih latest firmware but after flashing same issue!! Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Processing MCU file: rm639__05.65.mcusw [BB5,XSR 1.6] size: 30.64 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Pooling for ADL device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: E3909BA CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 2A00010DB19C03444B608ED15FA342DBFCA423C8 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Pooling for ADL device OK. Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: E3909BA Verifying communication to device OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35376404094676_CE RT.rpl" CMT PAPUBKEYS HASH: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C Storing certificate [NPC, CCC, HWC, R&D] ... Partitioning.... Partitioning complete Erase size: 45.06 MB Flash programming ... CMT PAPUBKEYS: 23B57C26A0C7A9C34544727AA1D2FC8F3265329C (RAP Certificate v1 260) written. Programming completed in 6.690 s Processing PPM file: rm639__05.65.ppm_d [BB5,XSR 1.6] size: 8.19 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 12.00 MB Flash programming ... Programming completed in 1.789 s Processing CNT file: rm639__05.65.image_d_0598107_007 [BB5,XSR 1.6] size: 31.65 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 66.06 MB Flash programming ... Programming completed in 6.832 s Total time for flashing process(boot+erase+write) was 30.242 s Pooling for ADL device ... Timeout, no usb device found. Flashing completed in 1 min 56.381 s Phone not responding ! waiting for reply br ; try a 1 time downgrad the phone & update ccc,hwc data |
03-01-2011, 14:00 | #10 (permalink) | |
Member: 890965 Status: Offline Sonork: 100.1605360 Thanks Meter: 180 | Quote:
04-14-2011, 12:51 | #11 (permalink) |
No Life Poster Join Date: Apr 2009 Location: INSIDE OUT
Member: 1015414 Status: Offline Thanks Meter: 155 | i have same problm ryt now i flash the fone so many time but still same...i rehote the flash ic...and guess wat the fone back to normalll...regards bro goodlock..100% tested by me |
The Following User Says Thank You to jasper-j For This Useful Post: |
04-20-2011, 09:44 | #12 (permalink) | |
No Life Poster Join Date: Jul 2006
Member: 315550 Status: Offline Thanks Meter: 110 | Quote:
yes tested also........ remove the shield - use blade cutter - cut the cover of the shied........... then reheat............ after that it will power normally | |
04-20-2011, 10:39 | #13 (permalink) | |
Junior Member Join Date: Apr 2011
Member: 1557882 Status: Offline Thanks Meter: 5 | Quote:
