IPmart Cables - http://www.ipmart-cables.com www.ipmart-cables.com |
03-25-2010, 07:58 | #18 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Rep Dom Age: 38
Member: 884906 Status: Offline Sonork: none Thanks Meter: 77 | here shows you how to connect cell phones RapidShare: 1-CLICK Web hosting - Easy Filehosting and this is the selector of the cables, and also tells you that you must select resistance value depending on model RapidShare: 1-CLICK Web hosting - Easy Filehosting do not forget to press the button thanks, greetings and enjoy |
The Following User Says Thank You to boliargsm For This Useful Post: |
03-25-2010, 11:59 | #19 (permalink) | |
Junior Member Join Date: Oct 2009 Location: Brazil Age: 39
Member: 1135057 Status: Offline Thanks Meter: 16 | Quote:
You only need to connect these two cables, VPP and BSI and nothing else. If the device does not come into LOCAL MODE yourself a hold on the power button and ready. It is not necessary to use the ground. Good Luck! | |
03-26-2010, 12:34 | #20 (permalink) | |
Freak Poster Join Date: May 2009 Location: Vendas Novas, Portugal
Member: 1023337 Status: Offline Sonork: 100.1617970 Thanks Meter: 16 | Quote:
i thank for all help but i still cannot connect any phone! i have a ub and jaf, i try with the explaination on jaf, make jump from gnd to box like tell the toturial but no read phone. :s br, foxis | |
03-26-2010, 21:07 | #21 (permalink) |
Member: 884906 Status: Offline Sonork: none Thanks Meter: 77 | how are you making the connection??? positive hook on pin VBAT is positive for the phone, and hook bsi pin goes neutral. only use the positive pin and pin-neutral phone. do not use the gnd. try it and write me the result, my msn is [email protected] luck. |
03-27-2010, 11:38 | #22 (permalink) |
Member: 1023337 Status: Offline Sonork: 100.1617970 Thanks Meter: 16 | i try today in nokia e65 with ub and can't connect phone! i connect vbat on positive and bsi on neutral without gnd. in ub i connect "jaf 8 pin". br, foxis |
03-27-2010, 12:44 | #23 (permalink) | |
Use the cable BB5 3 and follow this picture. It contains the pinout and value of the resistor. Do not forget to put the key of the resistors in 7.5 Tip: Place the cable into the phone, plug VBAT and BSI and then plug the cable UFC into your box. If necessary hold ond power button. Good Luck! | |
03-27-2010, 15:16 | #26 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: bestncheap Age: 43
Member: 19785 Status: Offline Thanks Meter: 1,242 | Quote:
so just need bsi and vcc allready enough.. BR BnC | |
05-21-2010, 00:08 | #28 (permalink) | |
Junior Member Join Date: Oct 2008
Member: 876305 Status: Offline Thanks Meter: 0 | Quote:
Links do not work. Could you please re upload. I need to know the values of the resistors. | |
Switch Mode Adapter 3in1 Pro Version BX SERIES by IPMART | bestncheap | IPmart Cables - http://www.ipmart-cables.com | 12 | 12-16-2009 20:15 |
I-Pmart BX series cables www.ipmart-cables.com | stallone1® | ipmart WebShop | 0 | 03-24-2009 11:07 |
Full Set 10 Pin iPmart BX Series Cable Compatible For Nokia BB5 For MT Box (BB5 only) | IPMART | ipmart WebShop | 0 | 03-14-2009 07:50 |
Full Set iPmart BX Series Cable Compatible For Nokia BB5 For JAF / UFS / N-Box (BB5 | IPMART | ipmart WebShop | 0 | 03-14-2009 07:50 |
