07-15-2005, 13:55 | #1 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Roma Age: 49
Member: 5926 Status: Offline Thanks Meter: 275 | 4in1 uc-10 cable not work on Sharp 902? SE and LG works ok but with Sharp not connecting it needs modifications? anyone knows? BR Rak|m |
07-15-2005, 16:14 | #3 (permalink) |
Member: 5926 Status: Offline Thanks Meter: 275 | realy? and SE no need this com port! 10x for reading my post without atention and reply what? (nothing) or u need to grow your posts number? answer just if u know something please BR Rak|m |
07-16-2005, 03:33 | #4 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: Boston
Member: 21920 Status: Offline Thanks Meter: 10 | Quote:
Take it apart and take apart a working t28 type connector. Then solder the connectors according to Lead's pinout. With Sharp you will have extra wires from the t28 that can be trimmed. | |
07-16-2005, 10:15 | #6 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: Athens - Greece
Member: 59935 Status: Offline Thanks Meter: 131 | Quote:
I have this prob. somethimes too. No need modifications !!! Just use 3v adapter conected to cable !! regards | |
07-16-2005, 11:54 | #7 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 62
Member: 63042 Status: Offline Thanks Meter: 117 | I have mine same problem with new sharp cable only, so i recheck the connections basing on schematics provided on cruiser cable help n able to found 2 connections shorted due to excess lead. after removing its working. |
07-17-2005, 20:14 | #8 (permalink) |
No Life Poster Join Date: Mar 2002 Location: gsmcity Age: 45
Member: 10505 Status: Offline Sonork: 100.40828 Thanks Meter: 364 | You need 3V power supply and follow instructions the_laser (C): "let me post quick tutorial for sharp flashing and unlocking. first if you had no special side connector cable, you can use phone handsfree connector to make it. second remove battery from phone. start setool2, press unlock. now, insert cable in phone. insert battery. if boot process not begins, then SHORTLY press power on. then just wait 16 seconds (if any errors like : rsa not accepted, checksum mismatch, etc - your cable is wrong or speed is too high) flashing. i suggest only flashing through usb cable, it will save your time and nerves. usual SPST flashes can be used, and special .cry files can be used. add all .ssw files in package to firmwares window in sharp tab. attach usb cable to phone, NOT INSERT BATTERY. press flash. as progressbar go, insert SIDE CONNECTOR cable in phone. phone must boots. if not, reinsert com cable. if still not boots - you have wrong usb or com cable. after boot process,phone will try to switch to usb. FIRST TIME, IT WILL FAIL AND ASKS FOR DRIVER ! THAT IS NORMAL. just point windows to drivers\usb_flash_driver and then repeat process. full firmare flashing over usb takes for me about 12 minutes. flashing through com... well... LONG. hope you will succeed." This method and 4 in 1 cable already tested by me with SHARP 802SH. BR levsha |
UC-20 cable not working | sajidmirza | Cruiser Suite | 7 | 09-07-2009 23:22 |
scdr2 x-5 cable not working on v55 | shruti | SagMaster Team OLD Products | 1 | 12-15-2006 06:07 |
USB Cable not working on Z1010? | Pauly__86 | TOTAL MultiServer | 2 | 12-16-2004 12:19 |
Fighter cable and UC-10 cable QUESTION.. Please help. | amigo_rk | Cruiser Suite | 1 | 12-08-2004 03:28 |
