11-22-2005, 14:49 | #1 (permalink) |
Freak Poster Join Date: Feb 2003 Age: 42
Member: 22109 Status: Offline Thanks Meter: 0 | Convert K750i to W800i - Help needed! I have a customer comming to get his K750i converted to a W800i in a few hours, so I need to make sure what the procedure is: 1. Connect phone using autodetection 2. Replace RED CID36 certificate to BROWN CID 36 3. Flash RAW_FS File (R1N035 from support) 4. Flash MAIN_FS File (R1N035 from support) 5. Replace Brown CID 36 certificate back to RED CID 36 6. Done Can someone confirm that it's the right way to do it? Thanks in advance Best regards Martin |
11-22-2005, 14:57 | #2 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Slovakia Age: 46
Member: 5155 Status: Offline Thanks Meter: 7 | hi, i am not sure about changing certificates but u mus: 1. flash MAIN 2. flash RAW FS 3. customize FS 4. shutdown FS i think this will be enought, of course if u not need unlock etc... BR krtko |
11-22-2005, 15:05 | #3 (permalink) |
Member: 22109 Status: Offline Thanks Meter: 0 | @krtko So I have to flash MAIN_FS before RAW_FS ?? Is that correct? I'll also need to unlock the phone, but I'll wait with that until I have manged to flash the phone. The help-file says that I should just push unlock RSA before flashing so I really don't know exactly what to do! Best regards Martin |
11-22-2005, 15:07 | #4 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 47
Member: 120328 Status: Offline Thanks Meter: 243 | Quote:
11-22-2005, 15:10 | #5 (permalink) | |
2. flash RAW FS 3. customize FS 4. shutdown FS this is upload ur phone flasfiles r1l002 taiwan files..succes ur phone convert w800! | |
11-22-2005, 15:13 | #7 (permalink) |
Member: 22109 Status: Offline Thanks Meter: 0 | @all Should I also flash Full_GDFS ? (to remove serviceprovider customizations) What is actually the difference between unlock RSA and flashing en new Certificate ?? Best regards Martin |
11-22-2005, 15:14 | #8 (permalink) |
Member: 120328 Status: Offline Thanks Meter: 243 | upload ur flash files is r1n035.. ur phone maybe 6closed ur phone... after flash ur to r1n035 maybe this after boot pleasewait..... |
11-22-2005, 15:17 | #9 (permalink) | |
11-22-2005, 17:50 | #11 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 44
Member: 134437 Status: Offline Thanks Meter: 2 | for me i did 1 attach phone 2 remove rsa 3 flash main FW 4 write raw FS 5 customise FS 6 shutdown Turn on phone and wait for the phone to complete its customization and voila you have a w800 in the case that when you on the phone and the please wait bar hang then you 1 convert to brown 2 direct unlock 3 convert back to red turn on phone and it should not hang. |
11-22-2005, 19:04 | #12 (permalink) |
Member: 22109 Status: Offline Thanks Meter: 0 | I would just like to let everyone know, that converting an K750i to a W800i is very easy with cruiser. Simply just flash firmware R1N035 into the phone and followed the info in the help-file. It worked like a charm. Damm I LOVE MY CRUISER Best regards Martin |
11-29-2005, 14:29 | #13 (permalink) | |
Freak Poster Join Date: Sep 2002 Location: UK
Member: 15399 Status: Offline Thanks Meter: 3 | Quote:
1. Attach phone 2. Unlock RSA 3. Convert to Browm CID 4. Flash Main 5. Write RAW 6. Customise FS 7. Shutdown FS 8. Detatch Phone. If anyone is using Cruiser and can't do it, pm me with you e-mail and i'll send you very easy guide to do it | |
11-29-2005, 16:54 | #15 (permalink) | |
Go to the Primary Page of the Control Window. Turn the phone off and attach it to the cable (select "Attach To Phone"). If using auto-detect phone type (the default) be sure Cruiser has correctly identified your phone type. If not, detach the phone, remove and insert the battery and then manually select your phone type from the menu. If necessary, select the Locks tab and press "Unlock RSA". Then reattach the phone. Select your desired language and the desired filesystem (languages are stored in the filesystem image). Be sure to match the correct firmware with the correct filesystem. Select the Flash tab, press "Flash ARM" and select the Firmware image to flash to the phone, Cruiser will then flash the Firmware to the phone. Select the File System tab, press "Write Raw FS" and then select the FileSystem image. Cruiser will then flash the FileSystem to the phone. Select the "Customize FS" option, then flash the correct cusomisation file for the type of phone you're flashing. You may use one of the built-in customizations too. If you forget to do this step when you power the phone on you will recieve the message "Configuration Error..." on the display. Select "Shutdown FS" and detach the cable. Hope this helps anyone, Mike | |
how to convert k750i to w800i | jinto123 | Cruiser Suite | 6 | 10-23-2006 20:16 |
How to convert k750i to w800i | Rutweiler | Sony Ericsson | 2 | 08-25-2006 16:16 |
Which Flash File to Convert K750i to W800i | spudpickermcfly | SonyEricsson (USB-Smart) | 5 | 05-23-2006 11:04 |
cONVERT k750I TO w800I Help Please | Gaz29 | Sony Ericsson | 1 | 03-15-2006 09:13 |
Converted D750i to K750i to W800i Help need for SEUS | Gaz29 | Sony Ericsson | 1 | 03-15-2006 09:05 |
