To Cruiser Support Vista Problem Hi: I m trying to install my box on my laptop with Vista (AMD Turion 64 2.2GHz 766Mb Ram Vista 32 bits) but when Cruiser 13.20 is installing it says ¨Failed to start SmartCard service¨ and therefore when I open software my box serial number is only ?????????? and dont work. I try over and over again but always same thing. Any solution?, please help. Thanks in advance. |
just ignore it and continue. for the smartcard use this driver: http://ultimate.philipfotos.com/e-ga...2_winvista.rar |
Thanks but did you test them personaly when i install vista show blue screen |
I did and am using them on Vindows Vista Business and Ultimate (both 32bit). I haven´t gotten any problem. |
I am using it on Vista Ultimate X64 without any problem. Br Bernie |
Thanks for your answer, but how can I do for make windows change drivers, cause my box appears as ¨unknown device¨ in ¨USB Device¨tab and when I try to update drivers it says ¨there is no controller for 32 bit windows¨. Please help. Thanks a lot. |
unknown device means broken USB cable, badly plugged smart card in (re-plug it) or broken card reader - change it. |
Support has nothing to say??? I changed cable, changed usb port and still the same, ¨unknown device¨, I think it is cause during install software can't start smart card service. Any other sugestion????????, Please????????? |
It will be broken card reader.. Do you have just reader or box version like that? http://img.diytrade.com/cdimg/553813..._Pro_3_Box.jpg If you have box version, disassembly it and check the motherboard out (rehot pins, atc) or use a new card reader: http://www.gsm-technology.com/multic...reader_400.jpg If you do not have one, get it from: http://www.ipmart.com/main/product/S....php?prod=6026 you said: I think it is cause during install software can't start smart card service. It´s absolutelly not true. The smartcard service couldn´t be started on win. vista during the installation Cruiser 13.20 (into a formated PC) because the smartcard drivers are not for win vista. You have to use those which I attached. |
