03-24-2009, 13:31 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 49
Member: 168935 Status: Offline Thanks Meter: 2 | To Cruiser Support Vista Problem I m trying to install my box on my laptop with Vista (AMD Turion 64 2.2GHz 766Mb Ram Vista 32 bits) but when Cruiser 13.20 is installing it says ¨Failed to start SmartCard service¨ and therefore when I open software my box serial number is only ?????????? and dont work. I try over and over again but always same thing. Any solution?, please help. Thanks in advance. |
03-24-2009, 14:14 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | just ignore it and continue. for the smartcard use this driver: http://ultimate.philipfotos.com/e-ga...2_winvista.rar |
03-24-2009, 17:28 | #6 (permalink) |
Member: 168935 Status: Offline Thanks Meter: 2 | Thanks for your answer, but how can I do for make windows change drivers, cause my box appears as ¨unknown device¨ in ¨USB Device¨tab and when I try to update drivers it says ¨there is no controller for 32 bit windows¨. Please help. Thanks a lot. |
03-24-2009, 22:28 | #8 (permalink) |
Member: 168935 Status: Offline Thanks Meter: 2 | Support has nothing to say??? I changed cable, changed usb port and still the same, ¨unknown device¨, I think it is cause during install software can't start smart card service. Any other sugestion????????, Please????????? |
03-24-2009, 23:32 | #9 (permalink) |
Member: 135110 Status: Offline Thanks Meter: 302 | It will be broken card reader.. Do you have just reader or box version like that? http://img.diytrade.com/cdimg/553813..._Pro_3_Box.jpg If you have box version, disassembly it and check the motherboard out (rehot pins, atc) or use a new card reader: http://www.gsm-technology.com/multic...reader_400.jpg If you do not have one, get it from: http://www.ipmart.com/main/product/S....php?prod=6026 you said: I think it is cause during install software can't start smart card service. It´s absolutelly not true. The smartcard service couldn´t be started on win. vista during the installation Cruiser 13.20 (into a formated PC) because the smartcard drivers are not for win vista. You have to use those which I attached. |
SERVER STATUS - USE Panel V 2.3.0.7 - Upgrade/Installation/Support Server Problems | GsmMunna | HWK | 1801 | 05-18-2023 13:08 |
To PB2 Support Vista Problem :::ANSWERED::: | gaspardiana | PolarBox 3 | 2 | 03-24-2009 17:01 |
how come i can't login to cruiser support d??? | fasangzai | Cruiser Suite | 0 | 12-11-2007 05:42 |
cant login to cruiser support | philip4 | Cruiser Suite | 3 | 01-30-2007 21:39 |
important to twister support plz problem in my twister | CONTACT-GSM | Twisterflasher | 7 | 09-24-2004 01:26 |
