Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 03-10-2007, 19:36   #1 (permalink)
Registered User
Member: 274461
Thanks Meter: 17
w600 almost dead.. help!!
Hi.. i have a w600 with some problem there is..
i connect phone but it wont boot.. always detach phone automatically and no flashing tasks options are showed..
[ --- Attach to Phone --- ]
Connecting via Fighter USB Cable...
Powering on the phone...
Baseband chip ID: 0x8040
Protocol version: 3.1
Baudrate = 115200Bd
Booting via ROM...
Sony Ericsson phone detected.
Phone CID: 49
Phone color: Brown
Flash certificate: A1_DB2010_49_BROWN
Trying Brown CID49 flash applet...
Sending applet prologue...
Sending applet body...
Time spent entering bootstrap: 4s
Initializing phone hardware...
Applet ID: 060206 1814 NPACXC125872_COMPACTPRO...
Flash manufacturer: Intel
Flash ID: 0x890D
OTP Security Level: 1 (Retail)
OTP CID: 49
Sending applet...
Terminating threads...
All threads terminated.
tried many baudrate already.. and model selected correctly.. help me please..
i tried also recovery boot cid49
No response
This may indicate damaged EROM area!
Try repairing the phone via testpoint method.
If it is an old phone, try converting it to brown first.
sad...
Old 03-10-2007, 19:48   #2 (permalink)
mrmcox's Avatar
Member: 273918
Hi, I have mentioned this in a few posts now, but not sure if anyone has tried it.
Install cruiser v9.68 and flash gdfs file. Then perform full flash, ie flash fs , customise, flash main. I have had many phones with this error
"No response
If it is an old phone, try converting it to brown first."
I only get these errors on versions 10.xx and not in 9.68. Please try and post results. If you cant find 9.68 msn me and i'll send u it.
regards, mark
Old 03-10-2007, 20:02   #3 (permalink)
Registered User
Member: 274461
Thanks Meter: 17
hey.. im online i added u.. are u off? can u addme please.. or accept me..
Old 03-10-2007, 20:02   #4 (permalink)
mrmcox's Avatar
Member: 273918
here is link for 9.68 cruiser:
http://md.gsmdownload.net/Software_G..._installer.rar
regards, mrmcox
Old 03-10-2007, 20:06   #5 (permalink)
Registered User
Member: 274461
Thanks Meter: 17
thanks.. but after connecting with this version task for flashing are show?
becuz with 10.39 no task can be used.. always detach in sending aplet in 1%
thanks
Old 03-10-2007, 21:44   #6 (permalink)
Registered User
Member: 274461
Thanks Meter: 17
ok phone connected fine with 9.68 but.. after flashing gdfs, arm, raw, and cuztomise.. it stucks in please wait it didnt progress the bar.... then.. try direct unlock but says GDFS Error: EAccessViolation
PD: Please cruiser team.. fix this bug in 10.39 and next version please.. this happens with many fones.. not only in w600 i got a k510a before too... thanks
Old 03-10-2007, 23:38   #7 (permalink)
MATRIX.REAL's Avatar
Member: 202333
Thanks Meter: 178
Arrow
yes
in this case , you must use TEST POINT(you found TEST POINT on MANUEL)
and do REPAIR EROM and REPLACE / REPAIR CERTIFICATE
then you will be able to flash as normally
Help, L7 almost dead. sphilip Smart-Clip 5 12-04-2006 10:10
w600 flash and dead help me idoniletisim Cruiser Suite 1 02-27-2006 13:57
Almost dead T720i :) Help me, please. Monty Motorola P2k 0 01-26-2004 20:51
T72o Almost dead HELP!! Raziel1984 Motorola P2k 9 08-23-2003 23:21
Almost dead SL45 fadi79 x1x to x45/x50 0 06-17-2002 20:50
Page generated in 0.16028 seconds with 9 queries
