03-10-2007, 19:36 | #1 (permalink) |
Registered User Join Date: May 2006
Member: 274461 Status: Offline Thanks Meter: 17 | w600 almost dead.. help!! i connect phone but it wont boot.. always detach phone automatically and no flashing tasks options are showed.. [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 115200Bd Booting via ROM... Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 4s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Sending applet... Terminating threads... All threads terminated. tried many baudrate already.. and model selected correctly.. help me please.. i tried also recovery boot cid49 No response This may indicate damaged EROM area! Try repairing the phone via testpoint method. If it is an old phone, try converting it to brown first. sad... |
03-10-2007, 19:48 | #2 (permalink) |
Freak Poster Join Date: May 2006 Location: East Coast UK Age: 43
Member: 273918 Status: Offline Thanks Meter: 0 | Hi, I have mentioned this in a few posts now, but not sure if anyone has tried it. Install cruiser v9.68 and flash gdfs file. Then perform full flash, ie flash fs , customise, flash main. I have had many phones with this error "No response This may indicate damaged EROM area! Try repairing the phone via testpoint method. If it is an old phone, try converting it to brown first." I only get these errors on versions 10.xx and not in 9.68. Please try and post results. If you cant find 9.68 msn me and i'll send u it. regards, mark |
03-10-2007, 20:02 | #4 (permalink) |
Member: 273918 Status: Offline Thanks Meter: 0 | here is link for 9.68 cruiser: http://md.gsmdownload.net/Software_G..._installer.rar regards, mrmcox |
03-10-2007, 21:44 | #6 (permalink) |
Member: 274461 Status: Offline Thanks Meter: 17 | ok phone connected fine with 9.68 but.. after flashing gdfs, arm, raw, and cuztomise.. it stucks in please wait it didnt progress the bar.... then.. try direct unlock but says GDFS Error: EAccessViolation PD: Please cruiser team.. fix this bug in 10.39 and next version please.. this happens with many fones.. not only in w600 i got a k510a before too... thanks |
03-10-2007, 23:38 | #7 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MATRIX.REAL
Member: 202333 Status: Offline Thanks Meter: 178 | yes in this case , you must use TEST POINT(you found TEST POINT on MANUEL) and do REPAIR EROM and REPLACE / REPAIR CERTIFICATE then you will be able to flash as normally |
Help, L7 almost dead. | sphilip | Smart-Clip | 5 | 12-04-2006 10:10 |
w600 flash and dead help me | idoniletisim | Cruiser Suite | 1 | 02-27-2006 13:57 |
Almost dead T720i :) Help me, please. | Monty | Motorola P2k | 0 | 01-26-2004 20:51 |
T72o Almost dead HELP!! | Raziel1984 | Motorola P2k | 9 | 08-23-2003 23:21 |
Almost dead SL45 | fadi79 | x1x to x45/x50 | 0 | 06-17-2002 20:50 |
