11-21-2008, 22:39 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sahara Desert Age: 77
Member: 150570 Status: Offline Thanks Meter: 52 | K800 Connection problem. Code: 21:31:23 SE Ultimate Unlocker v3.05 by Cruiser Team 21:31:23 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 21:31:23 Initializing... ! 21:31:23 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 21:31:23 2. Choose the phone model ! 21:31:23 3. Select the desired options ! 21:31:23 4. Please connect the phone either via USB while holding 2-5… ! 21:31:23 - or via a serial cable and double-click on it in the device list 21:31:53 Selected phone: K800 21:31:53 Connecting via Generic FTDI Cable (COM3)… 21:31:53 Device driver version: 2.4.6.0 21:31:53 Device driver date: 3-13-2008 21:31:54 Connecting to the baseband CPU... 21:31:54 Entering baseband CPU service mode... 21:31:54 Detected chipset: DB2020 21:31:54 Boot mode: ROM 21:31:54 Sending loader... E 21:31:55 Error: 0xA7AB9E28 E 21:31:55 Error data: 0xA7AB9E28 - 00000003:004513 E 21:31:55 Error: 0x82285E14 E 21:31:55 Error: 0xFF68B257 E 21:31:55 Error: 0x35A52603 E 21:31:55 Error: 0x45A1D7E8 E 21:31:55 Error: 0xD6E193F2 E 21:31:55 Failed! ! 21:31:55 To report errors right-click this window marty |
11-22-2008, 21:27 | #4 (permalink) |
Member: 150570 Status: Offline Thanks Meter: 52 | 13.20 log. Any help in teaching, as to how to identify problem, will be appreciated. System diagnostics passed. Version 13.20 ready! Do NOT connect the phone at this time! [ --- Attach to Phone --- ] Connecting via SEMC DCU-60... Connect the phone while holding its C button! USB connection established. Baseband chip ID: 0x9900 Protocol version: 3.1 Booting via EROM... Sony Ericsson phone detected. Phone CID: 52 Phone color: Red EROM version: R3A022 Trying CID52 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 0s Initializing phone hardware... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 51 Phone CID: 52 Phone color: Red Sending applet... Applet ID: 061205 1523 HANCXC9876543210_DB2020... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... RSA protection state cannot be determined for this CID. Phone hardware initialized OK With Com [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x9900 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Trying CID53 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Terminating threads... All threads terminated. The applet has intentionally turned the phone off! Script error: Unspecified [13.20.90] |
11-23-2008, 15:03 | #5 (permalink) |
Registered User Join Date: Feb 2006 Location: Ireland / Belarus
Member: 234917 Status: Offline Thanks Meter: 160 | Of course phone will be turned off - you must use DCU-60 cable with this phone. If you really need to upgrade the CID (I don't see any reason) then use DCU-60 cable with ultimate unlocker and post result. |
11-24-2008, 00:59 | #6 (permalink) | |
Member: 150570 Status: Offline Thanks Meter: 52 | Quote:
Marty | |
k800 mic problem | alhamde16 | Sony Ericsson Hardware Repair | 17 | 12-02-2010 11:28 |
K800 software problem | irfanamin2 | MT-BOX | 6 | 02-08-2008 10:38 |
k800 connection | smed | Cruiser Suite | 5 | 06-15-2007 12:59 |
K800 Connection Problem | exstazi | Cruiser Suite | 3 | 05-02-2007 05:27 |
k800 flashing problem!!! :mad: | lucik | Universalbox | 4 | 12-26-2006 20:03 |
