Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 11-21-2008, 22:39   #1 (permalink)
Member: 150570
Thanks Meter: 52
K800 Connection problem.
Trying to upgrade cid52 to cid53.
  21:31:23  SE Ultimate Unlocker v3.05 by Cruiser Team
  21:31:23  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  21:31:23  Initializing...
! 21:31:23  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 21:31:23  2. Choose the phone model
! 21:31:23  3. Select the desired options
! 21:31:23  4. Please connect the phone either via USB while holding 2-5…
! 21:31:23  - or via a serial cable and double-click on it in the device list
  21:31:53  Selected phone: K800
  21:31:53  Connecting via Generic FTDI Cable (COM3)…
  21:31:53  Device driver version: 2.4.6.0
  21:31:53  Device driver date: 3-13-2008
  21:31:54  Connecting to the baseband CPU...
  21:31:54  Entering baseband CPU service mode...
  21:31:54  Detected chipset: DB2020
  21:31:54  Boot mode: ROM
  21:31:54  Sending loader...
E 21:31:55  Error: 0xA7AB9E28
E 21:31:55  Error data: 0xA7AB9E28 - 00000003:004513
E 21:31:55  Error: 0x82285E14
E 21:31:55  Error: 0xFF68B257
E 21:31:55  Error: 0x35A52603
E 21:31:55  Error: 0x45A1D7E8
E 21:31:55  Error: 0xD6E193F2
E 21:31:55  Failed!
! 21:31:55  To report errors right-click this window
Can anyone please explain errors. Have tried using DCU-60 and Com cable
marty
Old 11-22-2008, 05:17   #2 (permalink)
FilipLudvik's Avatar
Member: 135110
Thanks Meter: 302
post an identify log by Cruiser 13.20.
Old 11-22-2008, 06:51   #3 (permalink)
nasagih's Avatar
Member: 551188
Sonork: 100.1580118
Thanks Meter: 59
for db2020 better u use dcu60. post the log as king filip said.
Old 11-22-2008, 21:27   #4 (permalink)
Member: 150570
Thanks Meter: 52
13.20 log. Any help in teaching, as to how to identify problem, will be appreciated.
System diagnostics passed.
Version 13.20 ready!
Do NOT connect the phone at this time!
[ --- Attach to Phone --- ]
Connecting via SEMC DCU-60...
Connect the phone while holding its C button!
USB connection established.
Baseband chip ID: 0x9900
Protocol version: 3.1
Booting via EROM...
Sony Ericsson phone detected.
Phone CID: 52
Phone color: Red
EROM version: R3A022
Trying CID52 recovery applet...
Sending applet prologue...
Sending applet body...
Time spent entering bootstrap: 0s
Initializing phone hardware...
Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_...
Flash manufacturer: Intel
Flash ID: 0x897E
OTP Security Level: 1 (Retail)
OTP CID: 51
Phone CID: 52
Phone color: Red
Sending applet...
Applet ID: 061205 1523 HANCXC9876543210_DB2020...
Sending applet...
Applet ID: 061201 1314 HANCXC1329129_DB2020_FL...
RSA protection state cannot be determined for this CID.
Phone hardware initialized OK
With Com
Connecting via Fighter USB Cable...
Powering on the phone...
Baudrate = 460800Bd
Booting via ROM...
Trying CID53 recovery applet...
Time spent entering bootstrap: 2s
Terminating threads...
All threads terminated.
The applet has intentionally turned the phone off!
Script error: Unspecified [13.20.90]
Old 11-23-2008, 15:03   #5 (permalink)
Registered User
Member: 234917
Thanks Meter: 160
Of course phone will be turned off - you must use DCU-60 cable with this phone. If you really need to upgrade the CID (I don't see any reason) then use DCU-60 cable with ultimate unlocker and post result.
Old 11-24-2008, 00:59   #6 (permalink)
Member: 150570
Thanks Meter: 52
Before posting, please read my question. First post is your answer.
Marty
k800 mic problem alhamde16 Sony Ericsson Hardware Repair 17 12-02-2010 11:28
K800 software problem irfanamin2 MT-BOX 6 02-08-2008 10:38
k800 connection smed Cruiser Suite 5 06-15-2007 12:59
K800 Connection Problem exstazi Cruiser Suite 3 05-02-2007 05:27
k800 flashing problem!!! :mad: lucik Universalbox 4 12-26-2006 20:03
Page generated in 0.16270 seconds with 9 queries
