08-01-2007, 10:22 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 47
Member: 170587 Status: Offline Thanks Meter: 16 | how to unlock vodafone v630i ??? need help thanx in advance |
08-01-2007, 10:35 | #3 (permalink) |
No Life Poster Join Date: Jun 2004 Location: E G Y P T Age: 40
Member: 70053 Status: Offline Thanks Meter: 85 | unlock RSA restore firmware flash main as it was in phone and then direct unlock no need to flash fs if u want to flash fs also so flash fs customize the phone and then direct unlock |
08-01-2007, 10:49 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Hong Kong | USA Age: 35
Member: 258172 Status: Offline Thanks Meter: 10,367 | Unlocking procedure: · Turn the phone on, then by pressing the >*<<*<* "secret" key sequence enter phone service menu. Go to the Service info submenu, then select the Software info item. Write down the first 2 or 3 lines describing the phone firmware version. · Attach the phone normally, preferably via DCU-60 or DCU-65 cable. · Go to the Security RSA tab and press the Unlock RSA button. One server credit will be deducted. · Note: Now the first 768KB of main firmware is overwritten, so it has to be restored or reflashed by a suitable main FW flash file. · Press the Restore firmware button. This operation restores the first 768KB damaged by the Unlock RSA operation provided the respective restoral file is found. If this operation fails, you need to reflash the whole main firmware by the same firmware version as written down in the first step. · Now go to the Locks tab and press the Read codes button. Wait a while, valid unlocking and relocking codes will be shown. Should this operation fail, you may try direct unlock immediately afterwards. · Turn the phone off (e.g. by pressing the <Ctrl-O> key combination). · Disconnect the phone from the cable, turn it on and by pressing the <**< "secret" key sequence enter the phone unlocking menu. Select locked items and enter the respective codes when asked. |
08-01-2007, 12:30 | #5 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | Just DON'T USE READ CODES, DO DIRECT UNLOCK!. Read Codes is faulty in Cruiser DB2020 unlocking, you can kill your phone. Direct unlock uses SETool patch method, so the phone will be unlocked but can't be flashed so it will become relocked again. Br |
how to unlock vodafone 533 plz help me sir | MOBIL CLINIC | SAGEM JTAG UNLOCKER | 12 | 01-13-2017 09:48 |
HOW TO unlock SE v600i ??please help | xiongfuchen | SETool2 | 15 | 05-21-2013 08:10 |
How to unlock C2205 Huawei need help | magucha | Infinity-Box | 0 | 01-02-2010 17:15 |
how to unlock vodafone v225 plz help | guy_askali | Infinity-Box | 4 | 01-25-2009 13:53 |
Need ''Vygis box" how to Unlock & flash need help with picture | mehedi.h.j | VygisToolbox | 0 | 08-18-2007 03:54 |
