09-06-2005, 20:37 | #1 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | K700i Hang at Lang selection menu http://mobile-*****.com/forum/showthread.php?t=13082 What about fixes for cruiser. I'll try it to making experiments with my k700i, and post the correct way for cruiser's users. But if someone already know how, please give directions. Thanks. BR, s1emens |
09-06-2005, 22:07 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | It's been fixed in Cruiser since 4.30 (I think it was 4.30 I might be wrong on the version) If you encounter such a phone just reflash RawFS, all will be well. |
09-07-2005, 04:34 | #3 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | Ok here is what I do: 1. Phone's 1st problem is when sim inserted phone freeze at Sony Ericsson Logo 2. Attach phone, Unlock RSA, Automatically detach 3. Unplug battery, Attach phone 4. Flash Main FW 5. Flash Raw FS 6. Customize FS 7. Shutdown FS, automatically detach Thats it, when phone turn on we have to wait at configuration. Then phone freeze at language selection menu, we have to unplug the battery to shut it down. If phone turn on without sim, all keys can be pressed and phone work normally. I'll try to flash the raw fs once more. Thanks BR, s1emens |
09-07-2005, 04:41 | #4 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | Try converting it to brown, direct unlocking it and converting it back to red again. That should fix it. If you've kept the phone CID29 you don't even have to do the color conversion, just direct unlock. |
09-07-2005, 18:03 | #5 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | @muppet Here is what I do. 1. Attach phone 2. Flash Raw FS 3. Customize with K700_generic.cc10 4. Shutdown FS, auto detach Problem still exist. Havent try with converting to brown, since phone is Red 29 and i flashed it using K700_CXC125821_EU1_R2AE033_Red29.ck7sw and K700_CXC125822_AsianLatin1_R2AE033_Red29.ck7fs. I kept the phone CID 29. Any other tips. I'll try to flash k700i gdfs but k700i gdfs is in flp format, how to flash this, since gdfs flashing is in mdc format? BR, s1emens |
09-07-2005, 20:13 | #11 (permalink) |
Member: 40602 Status: Offline Thanks Meter: 118 | This is eerchant post: Hi, this error was confirmed by SE itself and on oficial EMMA III server is fix to this problem (pure Software only problem), anyway i speak with Lead and he told me - just use version 4.30 and customize the phone...and when customizing the phone also this language menu hang shall be solved.... Regards Eerchant I believed we can't use v4.30 coz it will give warning expired version please using the newest version. Am i correct? @iki is this gdfs is compatible with cruiser? I also have this gdfs and also gdfs from the laser that fix this problem but it was meant for SEtool not cruiser. BR, s1emens |
FLASH k700 HANGING AT language select WITH CRUISER | HAMID-GSM | Cruiser Suite | 12 | 04-23-2007 20:46 |
S700i hangs on language select menu | trustunna | Cruiser Suite | 0 | 03-08-2007 14:08 |
k700 hang on language selection menu | 2xxu | Cruiser Suite | 6 | 04-20-2006 10:59 |
K700 hangs on language selection menu. Any help ? | Invader | HWK | 4 | 12-25-2005 16:50 |
2 k700i-s freezing at language select menu | jabran200 | SonyEricsson (USB-Smart) | 11 | 11-11-2005 07:00 |
