03-28-2009, 14:24 | #1 (permalink) |
Junior Member Join Date: Mar 2009
Member: 999039 Status: Offline Thanks Meter: 0 | Login to server failed. I bought a user name and password and then tried to unlock my phonw this morning, it has a connection issue i think, could you tell me whether the server is running. thanks. Here is my log: Code: 13:08:10 D-Ultimate Unlocker v3.07 by Cruiser Team 13:08:10 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 13:08:10 Initializing... ! 13:08:10 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 13:08:10 2. Choose the phone model ! 13:08:10 3. Select the desired options ! 13:08:10 4. Please connect the phone either via USB while holding 2-5 ! 13:08:10 - or via a serial cable and double-click on it in the device list 13:08:28 Selected phone: W595 13:08:28 Connecting via Generic EMP USB Flash Device (USB1) 13:08:28 Device driver version: 2.1.0.0 13:08:28 Device driver date: 3-20-2008 13:08:28 Connecting to the baseband CPU... 13:08:28 Entering baseband CPU service mode... 13:08:29 Detected chipset: DB3150 P3A/P3B/R3A 13:08:29 Boot mode: ROM 13:08:29 Sending loader... 13:08:32 IMEI: 35905102882234 13:08:32 OTP CID: 52 13:08:32 Product type: Retail 13:08:32 Effective color: Red 13:08:33 Sending loader... 13:08:37 Communicating with server E 13:09:39 Error: 0xE1E2479D E 13:09:39 Error: 0xE1E2479D E 13:09:39 Error: 0xB3A47971 E 13:09:39 Error: 0xB1A5E70E E 13:09:39 Error: 0xCDFE8536 E 13:09:39 Error: 0x3D1C4CBE E 13:09:39 Error: 0x3D35EAF1 E 13:09:39 Login to server failed E 13:09:39 Failed! ! 13:09:39 To report errors right-click this window |
03-28-2009, 15:11 | #4 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | check it with your reseller out. He might forgot activate your account or try to use this solution: http://forum.gsmhosting.com/vbb/show...ction+solution (read the whole thread) |
Login to server failed | mhmasoud | Cruiser Suite | 4 | 05-20-2009 17:36 |
Login to server failed | terry95 | Cruiser Suite | 3 | 04-21-2009 19:47 |
login to servir failed | hind paul | Cruiser Suite | 1 | 02-18-2009 11:04 |
Login to server failed why?? | falcon2 | Cruiser Suite | 6 | 01-17-2009 23:36 |
