06-21-2005, 16:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 17424 Status: Offline Thanks Meter: 15 | Need drivers for UC-10 USB cable Just managed to get USB cable with ps2 connectors . Computer detects it as Zenith Team Universal UC-10. Did not have any USB drivers (the guy was kind enough to sell me his own). Can any one please give me the link or drivers please ( I need to unlock Sharp 902) . I have tried the china cable drivers but they seems to insall ok but Cruser can not detect the cable. Thanks in advance for your help. br msa |
06-21-2005, 19:15 | #5 (permalink) |
Member: 17424 Status: Offline Thanks Meter: 15 | Hi Need a little bit more help please. When I try to attach the phone with Cruiser it says 'Powering Phone' and nothing happens, just sits there. I have tried to press on/off button buton the Cruiser screen shows red light flick but no further responce. I open the Ps2 connector cable (the end which plugs into phone) and see there is no 1k resistor ( I though bought cable should work ), is it absolutley necessary to have this resitor or should it work without it?. Any suggestions please. ps using V4.13 now . Thanks br msa |
06-21-2005, 20:16 | #8 (permalink) | |
Banned Join Date: Jan 2002 Location: Morocco , Tetouan
Member: 8784 Status: Offline Sonork: 100.63512 Thanks Meter: 31 | Quote:
There working drivers Regards . . | |
06-21-2005, 22:24 | #9 (permalink) | |
Member: 17424 Status: Offline Thanks Meter: 15 | Quote:
Thanks for the drivers. The drivers included in Cruiser install worked fine. Only problem now is the cable I think. I have dismantled the ps2 connector for Sharp 902se and the wiring configuration is different then the one shown in Leads schema. It looks like I am going to have to modify the cable, which was something I was trying to avoid as it is time consuming. Oh well you can't win'em all thanks br msa | |
06-22-2005, 10:56 | #10 (permalink) |
Member: 17424 Status: Offline Thanks Meter: 15 | Hi Finaaly manged to modify cable and connected . Now I get the message after attaching that 'Unlock RSA first' when I press 'Unlock RSa' nothing happens. I read another post that this firmware is not supported . Is this true?. this is the log of the phone: Ready! Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Sharp 3G phone detected. Phone CID: 24 Phone color: Brown Trying Brown CID24 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Flash manufacturer: Sharp Flash ID: B00B The connected phone is a prototype! OTP CID: 24 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 24 Primary certificate color: Brown Secondary certificate not found. OSE configuration found. Analysing GDFS... Done. Analyzing RSA protection... RSA protection is normal. Use the Unlock RSA function first! So what now please, Wait for Lead I spose . Thanks br msa |
06-28-2005, 18:23 | #11 (permalink) | |
Freak Poster Join Date: Aug 2003 Location: on earth Age: 56
Member: 36391 Status: Offline Thanks Meter: 0 | hi can u please help me out with the cable me havin same problems as you thanks in advance regards celcom icq :126373674 gsm killer Quote:
06-28-2005, 23:57 | #12 (permalink) |
Member: 17424 Status: Offline Thanks Meter: 15 | @celcom Hi you need to open the rectangular moulding for Sharp ps2 connector cable. The wires at ps2 side you need to swap as per Lead schema. Leave the cables as they are at phone connector side. If you still have problems then let me know and tommorow I will dig out the colours of the cable I modified. br msa |
06-29-2005, 12:16 | #13 (permalink) | |
Member: 36391 Status: Offline Thanks Meter: 0 | hi thanks for your reply i need more help please through colors , and if u have msn or icq please post so i can contact you directly once again thanks for your quick reply regards celcom Quote:
06-29-2005, 16:34 | #14 (permalink) |
Member: 17424 Status: Offline Thanks Meter: 15 | Hi Attached is the pin out of modified Sharp 902se connector (as I modified it). I hope this will help. br msa ps. Still can not unlock the phone though . Still wating for Lead to support this model. . |
06-30-2005, 14:41 | #15 (permalink) | |
Member: 36391 Status: Offline Thanks Meter: 0 | hi mate thanks for your help but my cable when i opened looks the same , from the connector side and from the other end , what did u do i really dont understand , but there are 4 colors , white , green , yellow and red .... what replacment did u do with these color s regards celcom Quote:
Need driver for LG KG800 USB driver | enrocas | SmartKey | 8 | 04-07-2009 06:53 |
Drivers for Sharp 703SH usb cable | arimob | FuriousGold | 3 | 06-17-2006 23:58 |
Driver for Samsung T809 USB Cable | Mickey Mouse | SWIFT Platform | 6 | 04-02-2006 13:29 |
Driver for unoriginal Siemens USB-cable? | James_S | Siemens-Benq RingTones and WallPapers | 1 | 02-21-2005 00:34 |
Driver for DCU-10 usb cable? | returburk | Old Ericsson Phones & Sony Phones | 1 | 07-09-2002 00:40 |
