04-03-2006, 04:25 | #1 (permalink) |
Insane Poster Join Date: May 2005 Location: Sweden Age: 54
Member: 148505 Status: Offline Thanks Meter: 0 | Newst W550i so strange can't flash FS Battry is full charg and all is ok i don't know how to fix this probem please suport me with solution best team. Best regards |
04-03-2006, 05:00 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Are you attaching to the phone using TP, then trying to flash RawFS? If so, this is wrong. The correct procedure is to attach to the phone, use TP to convert it to brown, detach, reattach to the phone normally (without TP) then Flash RawFS. If you are still getting an error after doing this, mostly likely you have encountered a faulty flash chip. You can try using some of the extended options (untick "check erase" and "verify data") but they'll probably only mask the fault. |
04-03-2006, 09:51 | #3 (permalink) | |
Freak Poster Join Date: Jul 2005 Location: www.gsm-ir.com Age: 44
Member: 159351 Status: Offline Sonork: 100.1576976 Thanks Meter: 179 | Quote:
please help me for my problem with new w550. i have a w550 that dead by bad flashing. but i cant flash it and try to convert it to brown several time but not convert. please help me [email protected] thanks | |
04-03-2006, 10:50 | #4 (permalink) | |
Member: 42570 Status: Offline Thanks Meter: 11 | Quote:
b) Why ask just me? There's lots of smart people here (and then there's me), direct your question to everyone. c) That's a terrible problem report. You said "can't flash" and "not convert". Care to explain WHY you can't flash? What's the error? In a new thread, explain in detail what you did, and post error logs (or screenshots of the problem) At the moment my suggestion, based on your report is "Hit it with a hammer" @Moursi: Apologies for the ongoing thread hijack. | |
04-03-2006, 12:15 | #5 (permalink) |
Member: 148505 Status: Offline Thanks Meter: 0 | Thanks Mr Muppet Thanks Mr.Muppet for quick replay i do right i attatch phone with TP covert to brown and reattatch normaly and write flash i get the same result sorry please if Mr leed have some solution for me to relife my phone back thanks. |
04-03-2006, 12:42 | #6 (permalink) |
Crazy Poster Join Date: Jan 2006
Member: 225444 Status: Offline Thanks Meter: 0 | Still problem? Why not try following flash options: Extended config - ON VPPFLASH=12V - OFF Check erase - OFF Verify data - OFF No erase - OFF I see that trick from Lead suggestion: http://forum.gsmhosting.com/vbb/showthread.php?t=271027 |
04-16-2006, 01:21 | #8 (permalink) |
No Life Poster Join Date: Apr 2004 Age: 62
Member: 63042 Status: Offline Thanks Meter: 117 | Still failed on FS flashing with Lead and muppet suggestions _untick "check erase" and "verify data". Stops at 42% . Can this be a faulty flash chip on a 2 weeks old phone? |
04-16-2006, 05:52 | #9 (permalink) |
No Life Poster Join Date: Apr 2005 Location: .... Ghari Matani ...... Age: 18
Member: 135601 Status: Offline Sonork: 100.1612518 Thanks Meter: 68 | i will try all method bt filez .. i thg its some bugs here .. i m sure cruiser team remove this bugs in coming update?? Br |
04-16-2006, 17:29 | #10 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Yes i think it will b removed in next update....Cruiser team is seeing everything in his product!!! Br Muneeb Akhtar Raza |
Can't flash NEC 338 | angel25dz | NEC | 0 | 03-29-2010 12:25 |
K310i Can't flash FS | simplex | Cruiser Suite | 8 | 03-28-2007 04:23 |
W550i new board(06W03) can't flash | minkes | Cruiser Suite | 3 | 02-08-2006 01:16 |
W550i stop flashing FS at 59%!!!! | zeozea | SonyEricsson (USB-Smart) | 3 | 12-28-2005 16:36 |
So TH4 can't flash? | kosmonaft | VygisToolbox | 10 | 08-13-2005 18:34 |
