01-11-2007, 12:50 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: india Age: 47
Member: 196194 Status: Offline Thanks Meter: 47 | p900 flash successful, but not switch on this is my first flashing.this cell p900 before flashing when s/w on SE logo appear and shut down. before flashing i charged the batt. 1 attach the cable to mobile with batt inside 2 click on attach button (slide the batt out for 5 sec and again inserted) 3 flash AVR P900_ phone_CXC162022_R3D011.AVR.FLP.....FLASH 100% 4 detach the phone from primary tab 5 removed the battery 5 removed the cable which was attach to mobile. 6 again insert the batt and cable to the mobile 7 in flash option their is flash PDA.I click the pda flash and select this file P900_Symbain_CXC162021_R3D011.PDA.FLP.....FLASH 100%. 8 again click on flash pda and select this file P900_APAC4_CDA1620038bin_R5A07.PDA.flp.......flash 100%. after this detach the mobile from primary tab and then removed the cable and battery.but when on the cell only dark blue screen.... please suggest me what to do know,is my flashing procedure was wrong?. Regards! |
01-11-2007, 13:13 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | change baudrate to 460800.. after flash avr part, make security zone and direct unlock detach flash PDA part`s with lower speed. BR, FL |
01-14-2007, 22:13 | #5 (permalink) |
Member: 196194 Status: Offline Thanks Meter: 47 | here is the rigth way to flash... thanks MR MUNEEB Bro u r wrong in ur 7th step....U must have to select P80x/P90x PDA option in primery tab left upper side....So here is the method how to flash it........ 1:Attach to phone 2:Flash AVR with AVR file 3eattach the phone 4:Now in primery tab left upper corner under "primery" Select P80x/P90x PDA option and press attach to phone... 5:Now press Flash Pda and flash symbian part 6:Again press Flash pda and flash the lang file... 7:Flash Bt(if needed....But in most cases no need to do so) 8:Now deattach 9:Now again in primery tab left upper corner select Standerd (dont wait) 10:Attach to phone 11:In security AVR tab press rebuild security zone.... 12:After complete al the steps power on ur phone...... If its software problem then set will 100%ok.... Note:If after pressing attach to phone button and it stops on powering on the mobile then pick out and reinsert battery.......And always remember to use full charged battery...ANd if again u have any problem then plz post here! __________________ BR MUNEEB AKHTAR RAZA Alway's Ready 4 Help!! i will post the result after flashing. REGARDS! |
02-15-2007, 14:05 | #8 (permalink) | |
Member: 196194 Status: Offline Thanks Meter: 47 | Quote:
till step no 8 all flasing ok( i skip step 7)b but when try to attach.. here is thelog..tried different baundrate System diagnostics passed. Version 10.36 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x5B08 Protocol version: 2.1 Booting via ROM... Trying CID29 applet... Trying CID27 applet... RSA protection feature inactive. Bypassing authority check... Time spent entering bootstrap: 37s Initializing phone hardware... Terminating threads... All threads terminated. Script error: Timeout [10.36.34] here is the file i flashed image attached.( in image customise folder i didn't used) battteryis 4.2v. regards! | |
help me my 7610 flash ok sucessfully but not switch on | s.r.yadav | Nokia Hardware & Hardware Repair | 11 | 12-08-2008 17:13 |
Nokia 2300 flashes but not switch on | nellabe | Nokia Hardware & Hardware Repair | 8 | 03-01-2007 18:49 |
T610 flashes but not switch on | Alkapone | Sony Ericsson Hardware Repair | 29 | 05-17-2006 15:55 |
E530 flashing successful but not on TST... :( | The SAINT® | TST Dongle | 24 | 09-01-2005 08:29 |
8250 flashes but not switches on | Bohosh | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-05-2004 22:28 |
