Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 05-10-2009, 22:04   #1 (permalink)
Member: 1027947
have cruiser 7 do not working with cs ultimate unlocker
I have cruser with ID 7 and I have supreme credit but it is not working every time I am trying to full GDFS reconstruction I get this problem
  19:26:28  SE Ultimate Unlocker v3.07 by Cruiser Team
  19:26:28  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  19:26:28  Initializing...
! 19:26:28  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 19:26:28  2. Choose the phone model
! 19:26:28  3. Select the desired options
! 19:26:28  4. Please connect the phone either via USB while holding 2-5…
! 19:26:28  - or via a serial cable and double-click on it in the device list
  19:26:41  Selected phone: K550
  19:26:41  Connecting via Generic FTDI Cable (COM4)…
  19:26:42  Device driver version: 1.0.2176.0
  19:26:42  Device driver date: 12-12-2005
  19:26:42  Connecting to the baseband CPU...
  19:26:42  Entering baseband CPU service mode...
  19:26:42  Detected chipset: DB2020
  19:26:42  Boot mode: ROM
  19:26:43  Sending loader...
  19:26:43  IMEI: 35851601937097
  19:26:43  OTP CID: 51
  19:26:43  Effective CID: 52
  19:26:44  Restarting phone …
  19:26:46  Sending loader...
  19:26:47  Communicating with server…
! 19:26:52  News: Your credit consumption policy: Level 1 (Novice)
  19:26:53  Remainig credit (supreme): 3.02
  19:26:56  Remainig credit (supreme): 2.69
  19:26:57  Restarting phone …
  19:26:59  Sending loader...
E 19:27:04  Error: 0xE1E2479D
E 19:27:04  Error: 0x07F5EFDA
E 19:27:04  Error: 0x916000B5
E 19:27:04  Error: 0x10BE36DC
E 19:27:04  Error: 0x59AF7680
E 19:27:04  Failed!
! 19:27:04  To report errors right-click this window
or
  18:31:28  SE Ultimate Unlocker v3.07 by Cruiser Team
  18:31:28  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  18:31:28  Initializing...
! 18:31:28  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 18:31:28  2. Choose the phone model
! 18:31:28  3. Select the desired options
! 18:31:28  4. Please connect the phone either via USB while holding 2-5…
! 18:31:28  - or via a serial cable and double-click on it in the device list
  18:31:37  Selected phone: K550
  18:31:37  Connecting via Generic EMP USB Flash Device (USB1)…
  18:31:37  Device driver version: 1.0.0.8
  18:31:37  Device driver date: 3-30-2006
  18:31:37  Connecting to the baseband CPU...
  18:31:38  Entering baseband CPU service mode...
  18:31:38  Detected chipset: DB2020
  18:31:38  Boot mode: ROM
  18:31:38  Sending loader...
  18:31:38  IMEI: 35851601937097
  18:31:38  OTP CID: 51
  18:31:38  Effective CID: 49
  18:31:40  Please reconnect the phone (disconnect, connect while holding 2-5)
E 18:31:48  Error: 0xE1E2479D
E 18:31:48  Error: 0x4D5EFC5D
E 18:31:48  Error: 0x8F9F6E1C
E 18:31:48  Error: 0x4B4AFEF3
E 18:31:48  Error: 0x319AC5CC
E 18:31:48  Error: 0x624C554E
E 18:31:48  Error: 0x753B3327
E 18:31:48  Error: 0x59AF7680
E 18:31:48  Failed!
! 18:31:48  To report errors right-click this window
can someone help mi please
Old 05-11-2009, 11:15   #2 (permalink)
BENCHENA's Avatar
Member: 116657
Thanks Meter: 56
perhaps it is HW problem what is the state of your phone ?
Old 05-11-2009, 22:07   #3 (permalink)
Member: 1027947
It is the same anser with all the phones wich I tryed with . more than 7 phones 3 of them was ok with out problem I want to check only if my cruiser working but it was the same anser .
it seems that it is some problem with the server or credit type or ...????
I had 3 credit wich is not supreme then i bought 5 supreme .I do not now if it is these 3 credits wich cause this problem??????
CS Ultimate Unlocker or D Ultimate Unlocker? dimitron D-Unlock Suite 2 02-06-2009 00:40
CRuiser -06 with CS ultimate unlocker david05 D-Unlock Suite 1 12-15-2008 04:50
do not work key mc60 after unlock with test point 123darius Siemens Hardware Repair Area 24 12-11-2007 17:51
T191 Proceeding calls do not work! With a computer not conect! Extreme Motorola ODM 1 05-27-2003 22:19
Page generated in 0.17867 seconds with 9 queries
