w810 cid50 unlocked by selecting k320i.... Thank's cruiser team,, http://i135.photobucket.com/albums/q...y_org/w810.jpg |
K530 cid52 with creating rest-file during unlock ok! BR Tomi |
K800i UNLOCKED SUCESSFULLY.HERE IS THE LOG 12:36:10 SE A1 Fast Java Unlocker v1.01 by Cruiser Team 12:36:10 Initializing... ! 12:36:10 1. Please see the documentation first (tab 'Info') ! 12:36:10 2. Choose the phone model ! 12:36:10 3. Please connect the phone while holding its C button… 12:36:21 Connecting via SEMC USB Flash Device (USB1)… 12:36:21 Device driver version: 2.1.0.0 12:36:21 Device driver date: 3-20-2008 12:36:21 Connecting to the baseband CPU... 12:36:21 Entering baseband CPU service mode... 12:36:22 Detected chipset: DB2020 12:36:22 Boot mode: EROM 12:36:22 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB 12:36:22 Sending loader... 12:36:22 Sending loader... 12:36:23 Sending loader... 12:36:24 Starting up System... 12:36:24 Starting up GDFS... 12:36:49 Starting up FS... 12:37:07 Done. ! 12:37:07 1. Disconnect the cable from the phone ! 12:37:07 2. Insert either a test-card or a SIM card which the phone accepts to the phone ! 12:37:07 3. Power on the phone by pressing the power ON/OFF button. ! 12:37:07 4. Go to the menu 'Entertainment' -> 'Games' and select/run the application 'executor' ! 12:37:07 5. Wait few seconds until the phone restarts by itself ! 12:37:07 6. Then the phone is unlocked, you may delete the 'executor' application from the phone |
S500i UNLOCKED SUCESSFULLY 12:36:10 SE A1 Fast Java Unlocker v1.00 by Cruiser Team 12:36:10 Initializing... ! 12:36:10 1. Please see the documentation first (tab 'Info') ! 12:36:10 2. Choose the phone model ! 12:36:10 3. Please connect the phone while holding its C button… 12:36:21 Connecting via SEMC USB Flash Device (USB1)… 12:36:21 Device driver version: 2.1.0.0 12:36:21 Device driver date: 3-20-2008 12:36:21 Connecting to the baseband CPU... 12:36:21 Entering baseband CPU service mode... 12:36:22 Detected chipset: DB2020 12:36:22 Boot mode: EROM 12:36:22 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB 12:36:22 Sending loader... 12:36:22 Sending loader... 12:36:23 Sending loader... 12:36:24 Starting up System... 12:36:24 Starting up GDFS... 12:36:49 Starting up FS... 12:37:07 Done. ! 12:37:07 1. Disconnect the cable from the phone ! 12:37:07 2. Insert either a test-card or a SIM card which the phone accepts to the phone ! 12:37:07 3. Power on the phone by pressing the power ON/OFF button. ! 12:37:07 4. Go to the menu 'Entertainment' -> 'Games' and select/run the application 'executor' ! 12:37:07 5. Wait few seconds until the phone restarts by itself ! 12:37:07 6. Then the phone is unlocked, you may delete the 'executor' application from the phone thank mr cruiser. |
Code: 16:30:47 SE A1 Fast Java Unlocker v1.00 by Cruiser Team |
UNLOCKED 2X W660i SUCESSFULLY. The log 21:01:14 SE A1 Java Unlocker v1.10 by Cruiser Team 21:01:14 Initializing... ! 21:01:14 1. Choose the phone model ! 21:01:14 2. Select main firmware flash file (*.a1sw) ! 21:01:14 3. Select raw FS flash file (*.a1fs) ! 21:01:14 4. Please connect the phone while holding its C button… 21:01:40 Connecting via SEMC USB Flash Device (USB1)… 21:01:40 Device driver version: 1.1.0.12 21:01:40 Device driver date: 9-25-2006 21:01:40 Connecting to the baseband CPU... 21:01:40 Entering baseband CPU service mode... 21:01:41 Detected chipset: DB2020 21:01:41 Boot mode: EROM 21:01:41 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB 21:01:41 Initializing flash files... 21:01:47 Sending loader... 21:01:47 Sending loader... 21:01:47 About to flash 42 MB of data… 21:07:30 Sending loader... 21:07:32 System starting up... 21:07:32 GDFS starting up... 21:07:50 FS starting up... 21:08:13 FS data uploading... ! 21:08:18 1. Please disconnect battery and cable from the phone! ! 21:08:18 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 21:08:18 3. Wait to customize finish ! 21:08:18 4. Turn off the phone ! 21:08:18 5. Please connect the phone while holding its C button… 21:10:36 Connecting via SEMC USB Flash Device (USB1)… 21:10:36 Device driver version: 1.1.0.12 21:10:36 Device driver date: 9-25-2006 21:10:36 Connecting to the baseband CPU... 21:10:36 Entering baseband CPU service mode... 21:10:37 Detected chipset: DB2020 21:10:37 Boot mode: EROM 21:10:37 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB 21:10:37 Sending loader... 21:10:37 Sending loader... 21:10:37 Sending loader... 21:10:39 System starting up... 21:10:39 GDFS starting up... 21:11:01 FS starting up... 21:11:04 FS data uploading... ! 21:11:13 1. Please disconnect battery and cable from the phone! ! 21:11:13 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 21:11:13 3. Connect the phone again ! 21:11:13 4. If asked, Install phone drivers ! 21:11:13 5. Choose 'PHONE MODE' in the phone ! 21:15:41 After choosing 'PHONE MODE' press the 'Ready' button 21:17:33 Connecting via SEMC WMC Device (COM15, COM14)… 21:17:33 Device driver version: 4.34.0.2705 21:17:33 Device driver date: 1-26-2007 ! 21:17:40 1. Please disconnect battery and cable from the phone! ! 21:17:40 2. Please connect the phone while holding its C button… 21:18:10 Connecting via SEMC USB Flash Device (USB1)… 21:18:10 Device driver version: 1.1.0.12 21:18:10 Device driver date: 9-25-2006 21:18:10 Connecting to the baseband CPU... 21:18:10 Entering baseband CPU service mode... 21:18:11 Detected chipset: DB2020 21:18:11 Boot mode: EROM 21:18:11 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB 21:18:11 Sending loader... 21:18:12 Sending loader... 21:18:12 About to flash 1 MB of data… 21:18:25 Done. ! 21:18:25 1. Please disconnect battery and cable from the phone! ! 21:18:25 2. Turn on the phone with inserted test card or sim card for which is the phone locked ! 21:18:25 3. Go to Entertainment and select Games. ! 21:18:25 4. Delete executor file. ! 21:18:25 5. Turn off the phone [/code] |
Im posted A1 Java Unlocker v1.10 log :eek::eek: sorry |
W580i Telcel méxico :cool: |
it is too easy with this javerunlocker why don't you do it some months before? K610i in few second phone is unlocked! Quote:
Z310i: 15:23:18 SE A1 Fast Java Unlocker v1.00 by Cruiser Team 15:23:18 Initializing... ! 15:23:18 1. Please see the documentation first (tab 'Info') ! 15:23:18 2. Choose the phone model ! 15:23:18 3. Please connect the phone while holding its C button… 15:24:25 Connecting via Generic EMP USB Flash Device (USB1)… 15:24:25 Device driver version: 1.1.0.12 15:24:25 Device driver date: 9-25-2006 15:24:25 Connecting to the baseband CPU... 15:24:25 Entering baseband CPU service mode... 15:24:26 Detected chipset: PNX5230 15:24:26 Boot mode: EROM 15:24:26 EROM version: R4A012 prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFL A_SIBLEY_SEMCUSB 15:24:26 Sending loader... 15:24:26 Sending loader... 15:24:28 Starting up System... 15:24:28 Starting up GDFS... 15:24:33 Starting up FS... 15:24:39 Done. ! 15:24:39 1. Disconnect the cable from the phone ! 15:24:39 2. Insert either a test-card or a SIM card which the phone accepts to the phone ! 15:24:39 3. Power on the phone by pressing the power ON/OFF button. ! 15:24:39 4. Go to the menu 'Entertainment' -> 'Games' and select/run the application 'executor' ! 15:24:39 5. Wait few seconds until the phone restarts by itself ! 15:24:39 6. Then the phone is unlocked, you may delete the 'executor' application from the phone :D:D:D |
Today : W610 , W350 , W580 and K770(cid53) t-mobile and vodafone hungary unlocked :) |
i love cruiser .. but .. what about for the repair imei ??? |
K550 cid52 succesfully unlocked BR Tomi |
heres mine k320 very fast bro!!!!!!! [IMG]http://i148.photobucket.com/albums/s...stunlocked.jpg[/IMG] |
