Can someone say what is difference between SE A1 Fast Java Unlocker v1.00 and SE A1 Java Unlocker v1.10 ????? SE A1 Fast Java Unlocker, cost credit?? Permanent Unlock ??? |
Read sticked thread about fast java unlocker, you will know answer. |
any solution for java unlock on w910i ? |
K310 cid 50 succesfully unlocked K310 cid 50 mexico Telcel sucesfully unlocked with A1 Java unlocker, thank's cruiser team. |
here is w200 log 18:21:31 SE A1 Fast Java Unlocker v1.01 by Cruiser Team 18:21:31 Initializing... ! 18:21:31 1. Please see the documentation first (tab 'Info') ! 18:21:31 2. Choose the phone model ! 18:21:31 3. Please connect the phone while holding its C button… 18:21:42 Connecting via SEMC USB Flash Device (USB1)… 18:21:42 Device driver version: 2.1.0.0 18:21:42 Device driver date: 3-20-2008 18:21:42 Connecting to the baseband CPU... 18:21:42 Entering baseband CPU service mode... 18:21:42 Detected chipset: DB2012 18:21:42 Boot mode: EROM 18:21:42 EROM version: R3A022 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLA FLA_SIBLEY_SEMCUSB 18:21:42 Sending loader... 18:21:43 Sending loader... 18:21:45 Starting up System... 18:21:45 Starting up GDFS... 18:21:55 Starting up FS... 18:22:06 Done. ! 18:22:06 1. Disconnect the cable from the phone ! 18:22:06 2. Insert either a test-card or a SIM card which the phone accepts to the phone ! 18:22:06 3. Power on the phone by pressing the power ON/OFF button. ! 18:22:06 4. Go to the menu 'Entertainment' -> 'Games' and select/run the application 'executor' ! 18:22:06 5. Wait few seconds until the phone restarts by itself ! 18:22:06 6. Then the phone is unlocked, you may delete the 'executor' application from the phone thanku cruiser team. |
15:34:30 SE A1 Fast Java Unlocker v1.00 by Cruiser Team 15:34:30 Initializing... ! 15:34:30 1. Please see the documentation first (tab 'Info') ! 15:34:30 2. Choose the phone model ! 15:34:30 3. Please connect the phone while holding its C button… 15:34:37 Connecting via SEMC USB Flash Device (USB2)… 15:34:37 Device driver version: 2.1.0.0 15:34:37 Device driver date: 3-20-2008 15:34:37 Connecting to the baseband CPU... 15:34:37 Entering baseband CPU service mode... 15:34:38 Detected chipset: DB2020 15:34:38 Boot mode: EROM 15:34:38 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB 15:34:38 Sending loader... 15:34:38 Sending loader... 15:34:38 Sending loader... 15:34:40 Starting up System... 15:34:40 Starting up GDFS... 15:34:54 Starting up FS... 15:35:04 Done. ! 15:35:04 1. Disconnect the cable from the phone ! 15:35:04 2. Insert either a test-card or a SIM card which the phone accepts to the phone ! 15:35:04 3. Power on the phone by pressing the power ON/OFF button. ! 15:35:04 4. Go to the menu 'Entertainment' -> 'Games' and select/run the application 'executor' ! 15:35:04 5. Wait few seconds until the phone restarts by itself ! 15:35:04 6. Then the phone is unlocked, you may delete the 'executor' application from the phone K530 - T-Mobile Croatia successfull :D |
infact cruiser term u are de best in dis world what a wounderfull software. CRUISER IS DE BEST. |
k800 full unlock Code: 14:45:46 SE A1 Fast Java Unlocker v1.01 by Cruiser Team |
another w200 unlock sucessful with a1 fast java unlocker Code: 17:49:12 SE A1 Fast Java Unlocker v1.01 by Cruiser Team |
K800i cid53 full unlock |
K810 cid53 unlocked ok! BR Tomi |
k800i,ands500i succefuly unlocked |
z310i with java fast unlocker still insert correct sim i did each in every thing i repeat steps more times the same please helping |
i tried same model,the other one unlocked while the other not. repeating same procedure still no lack. hope cruiser team will develop it in next update. phones tested and unlocked are k800,s500,k320,k310,z310,k550,k610, |
w200 cid 52 unlocked ok! |
