04-05-2009, 21:47 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: tunisia
Member: 207494 Status: Offline Thanks Meter: 22 | problem to conect s1 flasher ???????? with s1 flasher Code: 22:38:08 SE S1 Flasher & Unlocker v2.03 by Cruiser Team 22:38:08 Initialisation en cours… ! 22:38:08 1. Choisir le model du telephone ! 22:38:08 2. For flashing, select flash files and additional options ! 22:38:08 3. Double-click on the appropriate device (serial cable) ! 22:38:08 - or connect the phone via USB while holding its C button ! 22:38:15 Your card activation ID is: 2A50716911779AC6AAB9DA83061F0213-07 22:38:15 Communicating with server… E 22:38:36 Error: 0x1F41CF97 E 22:38:36 Cannot connect to the server E 22:38:36 Check server host name and port in the settings E 22:38:36 Echec! ! 22:38:36 Pour rapporter l'erreur cliquer droit sur cette fenetre Code: 22:39:37 SE Ultimate Unlocker v3.07 by Cruiser Team 22:39:37 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 22:39:37 Initialisation en cours… ! 22:39:37 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 22:39:37 2. Choisir le model du telephone ! 22:39:37 3. Select the desired options ! 22:39:37 4. Please connect the phone either via USB while holding 2-5… ! 22:39:37 - or via a serial cable and double-click on it in the device list 22:39:39 Communicating with server… ! 22:39:45 News: Your credit consumption policy: Level 1 (Novice) 22:39:47 Remainig credit (supreme): 1.01 22:39:47 Effectue. |
LG GD510 Problem to conect via Test Point! | mobile-phone-service | VygisToolbox | 15 | 04-08-2010 19:16 |
problem using S1 flasher & unlocker to unlock T303 | preshaust | Cruiser Suite | 32 | 02-27-2009 20:00 |
im have problem to conect ufsx hwk to soft | delchoni | HWK | 6 | 05-11-2008 12:14 |
D900 have problem to conecting ..? | communication_expert | UST Pro II | 0 | 12-14-2007 01:34 |
problem to conect with ufs3 | chowdary | UFS2 + UFS3-Tornadoflasher | 0 | 01-31-2005 23:12 |
